Hi
A simple question. I have compiled a simple program ( empty C main ).
My comiler is arm-none-linux-gnueabi-g++.exe
I have transfert the result to the beagleboard. When I execute this
program I obtain this error
-sh ./a.out permission denied
It is probable a simple linux error.
Thank you
Dear Geoffroy,
What does that hyphen do there?
That is why your problem is off-topic. Please use a different list next
time when you have such a problem not having to do with the BeagleBoard.
You should always verify such things on a different system, i. e. not
the BeagleBoard. You can install a distribution in a virtual machine for
example.
Anyways, what are the permissions of `a.out`? Please send the output of
the following command.
$ ls -la a.out # Without the »$« at the beginning.
Paul
