Hi all!
I guess this problem should long be solved, but I'm still running into this issue. I started today with a fresh install of KUbuntu 8.10 on my new system and a fresh checkout of the openembedded git-repository. Executing 'bitbake beagleboard-demo-images' results in:
NOTE: Running task 778 of 6737 (ID: 3649, /workspace/projekte/oe/openembedded/packages/shared-mime-info/shared-mime-info-native_0.51.bb, do_compile)
NOTE: package shared-mime-info-native-0.51: started
NOTE: package shared-mime-info-native-0.51-r0: task do_compile: started
ERROR: function do_compile failed
ERROR: see log in /workspace/projekte/oe/build/work/i686-linux/shared-mime-info-native-0.51-r0/temp/log.do_compile.17396
NOTE: Task failed: /workspace/projekte/oe/build/work/i686-linux/shared-mime-info-native-0.51-r0/temp/log.do_compile.17396
NOTE: package shared-mime-info-native-0.51-r0: task do_compile: failed
ERROR: TaskFailed event exception, aborting
NOTE: package shared-mime-info-native-0.51: failed
ERROR: Build of /workspace/projekte/oe/openembedded/packages/shared-mime-info/shared-mime-info-native_0.51.bb do_compile failed
ERROR: Task 3649 (/workspace/projekte/oe/openembedded/packages/shared-mime-info/shared-mime-info-native_0.51.bb, do_compile) failed
And the following error in the log:
mv -f .deps/update_mime_database-update-mime-database.Tpo .deps/update_mime_database-update-mime-database.Po
ccache gcc -I/workspace/projekte/oe/build/staging/i686-linux/usr/include/libxml2 -I/workspace/projekte/oe/build/staging/i686-linux/usr/include/glib-2.0 -I/workspace/projekte/oe/build/staging/i686-linux/usr/lib/glib-2.0/include -isystem/workspace/projekte/oe/build/staging/i686-linux/usr/include -O2 -Wall -Wstrict-prototypes -Wmissing-prototypes -Wwrite-strings -L/workspace/projekte/oe/build/staging/i686-linux/usr/lib -Wl,-rpath-link,/workspace/projekte/oe/build/staging/i686-linux/usr/lib -Wl,-rpath,/workspace/projekte/oe/build/staging/i686-linux/usr/lib -Wl,-O1-o update-mime-database update_mime_database-update-mime-database.o -L/workspace/projekte/oe/build/staging/i686-linux/usr/lib -lxml2 -lglib-2.0
/workspace/projekte/oe/build/staging/i686-linux/usr/lib/libxml2.so: undefined reference to `gzopen64'
collect2: ld returned 1 exit status
Full error log is attached.
I've also applied the patch mentioned in [1], but that didn't help (also did a bitbake -c clean for both libxml2 and shared-mime-info-native).
The same already happened on two other systems on which I tried to build the image, including another kubuntu 8.10 and a kubuntu 8.04 server-edition. The only system not showing this problem so far was a kubuntu 8.04 (non-server).
Any help would be greatly appreciated.
Stefan
Ref:
[1] http://groups.google.com/group/beagleboard/browse_thread/thread/0ca02e78e21709f1?fwc=1
log.do_compile.17396 (9.57 KB)
