1. Pushing the existing code to respective GIT tree : Long process.
2. Keeping complete source and binary images for others to use.
As mentioned in previous mail, I would like to post u-boot 1.3.3. and X-loader to code.google.com before that I would like to know:
- Should we have test cases for Audio tone and DVI logo ported from 1.1.4 to 1.3.3?
Let me know what other things we can add and what we can remove from existing x-loader and u-boot. I will incorporate your comments and upload the same.
Hopefully not so long. Or, better, hopefully long == several weeks, long != several month
Source: Please don't doublicate source repositories. It's always confusing and makes trouble. Binary: Yes. Proposal: Get uboot and xloader git, build binaries, put binaries to code.google.com and mention "this is build with git version xxx". For xxx easiest would be a label, but git hash will work as well (git checkout <hash> is easy).
I don't think audio and DVI has to be "ported". If I remember correctly, the audio and DVI stuff worked at 1.3.3 as well. We removed it cause of size and boottime reasons.
For upstream, audio and DVI has no chance. Once Beagle uboot support is upstream, I think we have to support some uboot git add on (patches) with stuff not upstream. E.g. this then will be "take uboot git for basic beagle boot functionality, if you like to have some nice add ons not upstream please apply these patches".
Who is "we"?
Please, don't do your own "fork" of Steve's git tree, nor put source snapshots of Steve's uboot tree at code.google.com. Yes, please feel free to *build* Steve's tree from time to time and put the resulting binaries at code.google.com.
Regarding Steve's uboot git tree, it would be really nice if you could help to clean it up. E.g. as already asked, we need help how to remove historical stuff e.g. ES1 support, clean up and fix pin mux, check clock configuration etc. Ideally, this help would be patches against Steve's git tree.
But again, please don't just put a fixed/improved uboot source blob at code.google.com and then do a "community, this is the master TI code, what's changed and how you get the changes/improvements into your (Steves) tree is your job". Please don't.
Sorry if I misunderstood anything, but in the past it happened several times that a "TI tree" (mainly kernels) appeared somewhere (with most probably quite good features and fixes), and it was always a pain to extract the improvements/changes and feed them back to mainline.
We started now to clean up the TI uboot source, so please help by working on this and don't publish an additional "TI uboot source v2".
Weeks for u-boot and x-loader but month(s) for features like Display in Kernel.
Source: Please don’t doublicate source repositories. It’s always
mention “this is build with git version xxx”. For xxx easiest would be
a label, but git hash will work as well (git checkout is easy).
Believe me I totally understand your concern, you have been helping TI for a much better software in community, your comment should be taken into account.
I don’t think audio and DVI has to be “ported”. If I remember
OK, no more tests or Logo in u-boot.
Who is “we”?
beagle community… :), my “We” on beagle discussion list is “beagle” community and not TI
Please, don’t do your own “fork” of Steve’s git tree, nor put source
snapshots of Steve’s uboot tree at code.google.com. Yes, please feel
free to build Steve’s tree from time to time and put the resulting
Ok, then we are going the GIT way for all sources, no more tar packages - right?
Dirk, you and me are from community so we can handle GIT stuff as suggested, but what about the app developers etc, will they be able to play around with GIT -?
I think with proper documentation even APP developers should be able to pull in GIT and do necessary modifications etc. Anyway this is the right procedure to work with Linux community so lets adopt this approach.
Then we need to host Bealge GIT for u-boot, kernel, x-loader, … and we need maintainers for the same.
Regarding Steve’s uboot git tree, it would be really nice if you could
Steve’s git tree.
I will work on cleaning up the u-boot code base.
But again, please don’t just put a fixed/improved uboot source blob at
code.google.com and then do a “community, this is the master TI code,
what’s changed and how you get the changes/improvements into your
(Steves) tree is your job”. Please don’t.
I was almost doing this :), Now I will stop this.
But we have work on hosting GIT trees for u-boot, kernel and X-loader.
Yes and no
No for upstream.
Yes for having a nice featured uboot for demos. The uboot beagle logo is quite impressive We have to find a way to maintain beagle uboot "add ons" which have no upstream chance but are nice to have. I would do it with "quilt controlled add on patches", but I'm sure that there is a git way as well.
I would not distinguish between "kernel" and "app" developers. Let us distinguish between binary only users and people willing to rebuild from source. We will put uboot binaries to code.google.com, then mention which git "label/hash" was the base for this. And anybody who feels that he has to rebuild, just can do it. I don't think for people willing to rebuild uboot from source, there should be no difference extracting a tar archive or getting a git tree and doing checkout xxx.
Agreed.
Then we need to host Bealge GIT for u-boot, kernel, x-loader, ... and we need maintainers for the same.
Steve's git tree.
I really like to see a patch from you (or anybody else with the knowledge) or at least a hint:
I'm not sure, but reading the comments it seems that for Beagle's GP device we can remove most of this?
code.google.com <http://code.google.com> and then do a "community,
Thanks! Good that we talked about it
? I think everything is already there and working, see above.
worked for me then. And today an update worked with "git pull"
- What about some (volatile) checkpatch errors?
As already discussed with Nishant, not all *kernel* checkpatch warnings seem to apply to uboot. E.g. this linux/io.h vs. asm/io.h is an other one.
What I currently plan to do for upstream are several steps:
1) Do the easy clean up: Remove easy checkpatch errors, remove #if 0 parts, remove historical stuff or other boards etc.
2) Then discuss with everybody if we need some code rewrite (e.g. what we can do with remaining warnings, do we need additional features or remove features).
3) Reorganize directories (names) and files (content). E.g. some days ago there was some discussion at IRC how to name cpu subdirecory.
Then we will split the remaining beagle patch into < 40k chunks and send them the first time to uboot list. And then, well, we will see
