I want to connect several individual wires to the BBB p9 header. I would rather not use an entire 46pin header to do this. Rather, I was thinking of finding some kind of single pin solder socket to solder on to the end of each wire and then push the pin into the appropriate header receiver pin number. Does anyone know of such a solder socket with the correct gold plated square pin to use? I tried to search digikey, etc. but don’t even know what the correct name for such a device would be.
David
