root@beagleboard:~# cat /var/lib/alsa/asound.state
state.omap3beagle {
control.1 {
comment.access 'read write'
comment.type ENUMERATED
comment.count 1
comment.item.0 'Option 2 (voice/audio)'
comment.item.1 'Option 1 (audio)'
iface MIXER
name 'Codec Operation Mode'
value 'Option 2 (voice/audio)'
control.2 {
comment.type INTEGER
comment.count 2
comment.range '0 - 63'
comment.dbmin -6300
comment.dbmax 0
iface MIXER
name 'DAC1 Digital Fine Playback Volume'
value.0 63
value.1 63
control.3 {
comment.count 2
comment.dbmin -6300
comment.dbmax 0
iface MIXER
name 'DAC2 Digital Fine Playback Volume'
value.0 63
value.1 63
control.4 {
comment.count 2
comment.range '0 - 2'
comment.dbmin 0
comment.dbmax 1200
iface MIXER
name 'DAC1 Digital Coarse Playback Volume'
value.0 2
value.1 2
control.5 {
comment.count 2
comment.dbmin 0
comment.dbmax 1200
iface MIXER
name 'DAC2 Digital Coarse Playback Volume'
value.0 2
value.1 2
control.6 {
comment.count 2
comment.range '0 - 18'
comment.dbmin -2400
comment.dbmax 1200
iface MIXER
name 'DAC1 Analog Playback Volume'
value.0 18
value.1 18
control.7 {
comment.count 2
comment.dbmin -2400
comment.dbmax 1200
iface MIXER
name 'DAC2 Analog Playback Volume'
value.0 18
value.1 18
control.8 {
comment.type BOOLEAN
comment.count 2
iface MIXER
name 'DAC1 Analog Playback Switch'
value.0 true
value.1 true
control.9 {
comment.count 2
iface MIXER
name 'DAC2 Analog Playback Switch'
value.0 true
value.1 true
control.10 {
comment.count 1
comment.range '0 - 49'
comment.dbmin -3700
comment.dbmax 1200
iface MIXER
name 'DAC Voice Digital Downlink Volume'
value 49
control.11 {
comment.count 1
comment.dbmin -2400
comment.dbmax 1200
iface MIXER
name 'DAC Voice Analog Downlink Volume'
value 18
control.12 {
comment.count 1
iface MIXER
name 'DAC Voice Analog Downlink Switch'
value true
control.13 {
comment.count 2
comment.range '0 - 3'
comment.dbmin -1200
comment.dbmax 600
iface MIXER
name 'PreDriv Playback Volume'
value.0 3
value.1 3
control.14 {
comment.count 2
comment.dbmin -1200
comment.dbmax 600
iface MIXER
name 'Headset Playback Volume'
value.0 3
value.1 3
control.15 {
comment.count 2
comment.dbmin -1200
comment.dbmax 600
iface MIXER
name 'Carkit Playback Volume'
value.0 3
value.1 3
control.16 {
comment.count 1
comment.dbmin -600
comment.dbmax 1200
iface MIXER
name 'Earpiece Playback Volume'
value 3
control.17 {
comment.count 2
comment.range '0 - 31'
comment.dbmin 0
comment.dbmax 3100
iface MIXER
name 'TX1 Digital Capture Volume'
value.0 31
value.1 31
control.18 {
comment.count 2
comment.dbmin 0
comment.dbmax 3100
iface MIXER
name 'TX2 Digital Capture Volume'
value.0 0
value.1 0
control.19 {
comment.count 2
comment.range '0 - 5'
comment.dbmin 0
comment.dbmax 3000
iface MIXER
name 'Analog Capture Volume'
value.0 5
value.1 5
control.20 {
comment.count 1
comment.item.0 'Voice high priority'
comment.item.1 'HiFi high priority'
iface MIXER
name 'AVADC Clock Priority'
value 'Voice high priority'
control.21 {
comment.count 1
comment.item.0 '27/20/14 ms'
comment.item.1 '55/40/27 ms'
comment.item.2 '109/81/55 ms'
comment.item.3 '218/161/109 ms'
comment.item.4 '437/323/218 ms'
comment.item.5 '874/645/437 ms'
comment.item.6 '1748/1291/874 ms'
comment.item.7 '3495/2581/1748 ms'
iface MIXER
name 'HS ramp delay'
value '27/20/14 ms'
control.22 {
comment.count 1
comment.item.0 'Vibra H-bridge direction'
comment.item.1 'Audio data MSB'
iface MIXER
name 'Vibra H-bridge mode'
value 'Vibra H-bridge direction'
control.23 {
comment.count 1
comment.item.0 'Positive polarity'
comment.item.1 'Negative polarity'
iface MIXER
name 'Vibra H-bridge direction'
value 'Positive polarity'
control.24 {
comment.count 1
iface MIXER
name 'Analog Right Sub Mic Capture Switch'
value false
control.25 {
comment.count 1
iface MIXER
name 'Analog Right AUXR Capture Switch'
value false
control.26 {
comment.count 1
iface MIXER
name 'Analog Left Main Mic Capture Switch'
value false
control.27 {
comment.count 1
iface MIXER
name 'Analog Left Headset Mic Capture Switch'
value true
control.28 {
comment.count 1
iface MIXER
name 'Analog Left AUXL Capture Switch'
value false
control.29 {
comment.count 1
iface MIXER
name 'Analog Left Carkit Mic Capture Switch'
value false
control.30 {
comment.count 1
comment.item.0 Analog
comment.item.1 Digimic1
iface MIXER
name 'TX2 Capture Route'
value Analog
control.31 {
comment.count 1
comment.item.1 Digimic0
iface MIXER
name 'TX1 Capture Route'
value Analog
control.32 {
comment.count 1
comment.item.0 'Local vibrator'
comment.item.1 Audio
iface MIXER
name 'Vibra Route'
value 'Local vibrator'
control.33 {
comment.count 1
comment.item.0 AudioL1
comment.item.1 AudioR1
comment.item.2 AudioL2
comment.item.3 AudioR2
iface MIXER
name 'Vibra Mux'
value AudioL1
control.34 {
comment.count 1
iface MIXER
name 'HandsfreeR Switch'
value true
control.35 {
comment.count 1
comment.item.0 Voice
comment.item.2 AudioR2
comment.item.3 AudioL2
iface MIXER
name 'HandsfreeR Mux'
value Voice
control.36 {
comment.count 1
iface MIXER
name 'HandsfreeL Switch'
value true
control.37 {
comment.count 1
comment.item.1 AudioL1
iface MIXER
name 'HandsfreeL Mux'
value Voice
control.38 {
comment.count 1
iface MIXER
name 'CarkitR Mixer Voice'
value true
control.39 {
comment.count 1
iface MIXER
name 'CarkitR Mixer AudioR1'
value true
control.40 {
comment.count 1
iface MIXER
name 'CarkitR Mixer AudioR2'
value true
control.41 {
comment.count 1
iface MIXER
name 'CarkitL Mixer Voice'
value true
control.42 {
comment.count 1
iface MIXER
name 'CarkitL Mixer AudioL1'
value true
control.43 {
comment.count 1
iface MIXER
name 'CarkitL Mixer AudioL2'
value true
control.44 {
comment.count 1
iface MIXER
name 'HeadsetR Mixer Voice'
value true
control.45 {
comment.count 1
iface MIXER
name 'HeadsetR Mixer AudioR1'
value true
control.46 {
comment.count 1
iface MIXER
name 'HeadsetR Mixer AudioR2'
value true
control.47 {
comment.count 1
iface MIXER
name 'HeadsetL Mixer Voice'
value true
control.48 {
comment.count 1
iface MIXER
name 'HeadsetL Mixer AudioL1'
value true
control.49 {
comment.count 1
iface MIXER
name 'HeadsetL Mixer AudioL2'
value true
control.50 {
comment.count 1
iface MIXER
name 'PredriveR Mixer Voice'
value true
control.51 {
comment.count 1
iface MIXER
name 'PredriveR Mixer AudioR1'
value true
control.52 {
comment.count 1
iface MIXER
name 'PredriveR Mixer AudioR2'
value true
control.53 {
comment.count 1
iface MIXER
name 'PredriveR Mixer AudioL2'
value true
control.54 {
comment.count 1
iface MIXER
name 'PredriveL Mixer Voice'
value true
control.55 {
comment.count 1
iface MIXER
name 'PredriveL Mixer AudioL1'
value true
control.56 {
comment.count 1
iface MIXER
name 'PredriveL Mixer AudioL2'
value true
control.57 {
comment.count 1
iface MIXER
name 'PredriveL Mixer AudioR2'
value true
control.58 {
comment.count 1
iface MIXER
name 'Earpiece Mixer Voice'
value true
control.59 {
comment.count 1
iface MIXER
name 'Earpiece Mixer AudioL1'
value true
control.60 {
comment.count 1
iface MIXER
name 'Earpiece Mixer AudioL2'
value true
control.61 {
comment.count 1
iface MIXER
name 'Earpiece Mixer AudioR1'
value true
control.62 {
comment.count 1
comment.range '0 - 41'
comment.dbmin -5100
comment.dbmax -1000
iface MIXER
name 'Voice Digital Loopback Volume'
value 0
control.63 {
comment.count 1
comment.range '0 - 7'
comment.dbmin -2400
comment.dbmax 0
iface MIXER
name 'Right Digital Loopback Volume'
value 0
control.64 {
comment.count 1
comment.dbmin -2400
comment.dbmax 0
iface MIXER
name 'Left Digital Loopback Volume'
value 0
control.65 {
comment.count 1
iface MIXER
name 'Voice Analog Loopback Switch'
value true
control.66 {
comment.count 1
iface MIXER
name 'Left2 Analog Loopback Switch'
value true
control.67 {
comment.count 1
iface MIXER
name 'Right2 Analog Loopback Switch'
value true
control.68 {
comment.count 1
iface MIXER
name 'Left1 Analog Loopback Switch'
value true
control.69 {
comment.count 1
iface MIXER
name 'Right1 Analog Loopback Switch'
value true
state.External {
control.1 {
comment.count 1
iface MIXER
name 'PCM Playback Switch'
value true
control.2 {
comment.count 1
comment.range '0 - 100'
comment.dbmin 0
comment.dbmax 0
iface MIXER
name 'PCM Playback Volume'
value 100
control.3 {
comment.count 1
comment.range '0 - 15'
comment.dbmin 0
comment.dbmax 2250
iface MIXER
name 'Mic Capture Volume'
value 0
control.4 {
comment.count 1
iface MIXER
name 'CMSS LED Switch'
value false
control.5 {
comment.count 1
iface MIXER
name 'Power LED Switch'
value true
