Specific GPIO pins in port 8 not working as Input
Hi all,
I am using Beaglebone black with Kernel version: 4.19.94-ti-r42 and in Port 8 only from Pin 11 to Pin 19 it is working as input when we give a 2.5 volt as input.
i am verifying this by logging into beaglebone black console with below linux command
Example:
Command: cat /sys/class/gpio/gpio71/value
But apart from Pin 11 to Pin 19 in port 8, no other gpio pins are working as input when we give the input voltage of 2.5 volt.
Can you please suggest any steps or suggest what is the problem in beaglebone black for the specifc gpio pins in port 8.
