SPIDEV0 and I2C issues on BBB in Python
I would expect this to be an easy question, but it has been beating me severely about the head and shoulders for the past week. I am running the 11.7 iot emmc flasher version (5.10) on a BBB. I have installed smbus2 If I attempt to use uboot_overlay_addr4=/lib/firmware/ADAFRUIT-SPI0-00A0.dtbo in the uEnv.txt file it doesn’t seem to work. I have switched to uboot_overlay_addr4=/lib/firmware/BB-SPIDEV0-00A0.dtbo. I am working out of VScode if that makes a difference. on just my SPI loopback test I get the following:
debian@BeagleBone:/dev$ python -u “/home/debian/examples/BeagleBone/test-spi.py”
Traceback (most recent call last):
File “/home/debian/examples/BeagleBone/test-spi.py”, line 11, in
spi = SPI(0,0)
PermissionError: [Errno 13] Permission denied
debian@BeagleBone:/dev$ sudo python -u “/home/debian/examples/BeagleBone/test-spi.py”
[32, 11, 110, 22, 220]
so I am not sure how to get the code window to run in sudo… Then the next issue pops up if I try to add smbus2 to the test.
debian@BeagleBone:/etc/udev/rules.d$ python -u “/home/debian/examples/BeagleBone/test-spi.py”
File “/home/debian/examples/BeagleBone/test-spi.py”, line 12, in
spi = SPI(0,0)
debian@BeagleBone:/etc/udev/rules.d$ sudo python -u “/home/debian/examples/BeagleBone/test-spi.py”
File “/home/debian/examples/BeagleBone/test-spi.py”, line 2, in
import smbus2
ModuleNotFoundError: No module named ‘smbus2’
at this point my test code looks like this:
from Adafruit_BBIO.SPI import SPI
import smbus2
From Adafruit Learning System:
SPI | Setting up IO Python Library on BeagleBone Black | Adafruit Learning System
#spi = SPI(bus, device) #/dev/spidev.
#spi = SPI(0,0) #/dev/spidev1.0
#spi = SPI(0,1) #/dev/spidev1.1
#spi = SPI(1,0) #/dev/spidev2.0
#spi = SPI(1,1) #/dev/spidev2.1
bus = smbus2.SMBus(1)
spi = SPI(0,0)
spiResponse= spi.xfer2([32, 11, 110, 22, 220])
print (spiResponse)
spi.close()
So how is it that smbus2 only runs not as root, and SPI on runs as root?
debian@BeagleBone:/dev$ ls /dev/spi* -al
crw-rw---- 1 root spi 153, 0 Sep 2 18:02 /dev/spidev0.0
crw------- 1 root root 153, 1 Sep 2 18:02 /dev/spidev0.1
crw------- 1 root root 153, 2 Sep 2 18:02 /dev/spidev1.0
crw------- 1 root root 153, 3 Sep 2 18:02 /dev/spidev1.1
what does your “dmesg | grep spi” output
i get
pinctrl-single 44e10800.pinmux: pin PIN84 already requested by ocp:P9_22_pinmu
x; cannot claim for 48030000.spi
[ 9.559314] pinctrl-single 44e10800.pinmux: pin-84 (48030000.spi) status -22
[ 9.566450] pinctrl-single 44e10800.pinmux: could not request pin 84 (PIN84) from group sp
i0_pins_s0 on device pinctrl-single
[ 9.577914] omap2_mcspi 48030000.spi: Error applying setting, reverse things back
[ 9.585511] omap2_mcspi: probe of 48030000.spi failed with error -22
one other thing that i’m seeing
No such file or directory: ‘/sys/devices/platform/bone_capemgr/slots’
don’t know much about Adafruit_BBIO.SPI, but it appears to be for older images
also, there’s
/opt/source/spidev-test
just compile it with gcc
a quick search, apparently Adafruit stuff is no longer supported
I get a command executed and failed (exit code 1) on the dmesg | grep spi
I did get things up and running on 10.3 finally. So I may just keep going down that path since the 5.10 kernel seems to be an unmitigated disaster.
It runs very well for us, we are even using the factory IoT image.
More than likely its your python code. Python is fine for certain applications, for controlling I/O it is the last choice. Big problem is python developers have you by the short hairs regarding I/O, you have to wait for them to fix the problem. When ever you abstract out the critical parts expect trouble. C/C++ is the only way to go if you demand world class software running your products.
