square wave output PWM but voltage change to 5V
I am outputting three square waves and I need to change the output voltage into 5V. Is there any way I can change the voltage?
I use Cloud9
Here is my code:
search mouser for voltage translator ICs
On Thu, 2 May 2019 13:00:02 -0700 (PDT),
quiteadream@gmail.com declaimed the
following:
I use Cloud9
Here is my code:
  Cloud9 and code is irrelevant... This is a hardware problem.
  You can not get 5V outputs from a Beagle without adding additional
hardware. Google "level shifter"
https://www.sparkfun.com/products/12009 (bidirection)
74AHCT125 - Quad Level-Shifter (3V to 5V) [74AHCT125] : ID 1787 : $1.50 : Adafruit Industries, Unique & fun DIY electronics and kits (one direction)
TXB0104 Bi-Directional Level Shifter [TXB0104] : ID 1875 : $3.50 : Adafruit Industries, Unique & fun DIY electronics and kits (bidirection)
Note that most of the bidirectional types are strictly signal level to go
from one chip to another. If you need to then drive larger loads (LEDs) you
may need to add a transistor or high-output buffer between the level
shifter and the load.
following:
>I use Cloud9
>Here is my code:
If *all* the OP wants to do is drive some load at 5V, an
open-collector/open-drain transistor is all that is needed.
