Is this available?
santosh
Is this available?
santosh
Are you asking if the BeagleBoard is available? If so, the answer is yes. Click on the “Buy It” button on the main beagleboard.org page.
No i meant SqueakVM (Smalltalk) on Beagleboard.
Oh! I get it! I will defer to the the SW part of the community to answer!
Op 17 dec 2008, om 00:04 heeft santosh balakrishnan het volgende geschreven:
It is available from the angstrom feeds in a few hours
regards,
Koen
# opkg update
# opkg install squeakvm
# opkg install squeakvm-plugin-display-x11
# wget http://ftp.squeak.org/3.10/Squeak3.10.2-7179-basic.zip
# unzip Squeak3.10.2-7179-basic.zip
# ln -s Squeak3.10.2-7179-basic.image squeak.image
# squeak
could not find display driver vm-display-X11; either:
- check that /usr/lib/squeak/3.10-1/vm-display-X11.so exists, or
- use the '-plugins <path>' option to tell me where it is, or
- remove DISPLAY from your environment.
Aborted
# ls -l /usr/lib/squeak/3.10-1/vm-display-X11.so
-rwxr-xr-x 1 root root 85408 Dec 16 2008 vm-display-
X11.so
