I received the board I won at LinuxTag some weeks ago. Now I found some time to
make something useful with it. For getting used with it I started with building
a GPE image for it. Koen did a good job... OE support for the Beagleboard is
pretty complete and seems to work well.
I tried both my own image and Koen's Beagleboard Demo image and got the same
result: The board is very unstable. It crashes during boot most of the time or a
short time after boot has finished. It just freezes - no output on he serial
port or the screen. Is this a known issue?
I have a rev. B4 board, USB powered and with both serial and DVI connected for
the tests. Both kernel/image combinations I booted from a SD card (Sandisk,
512MB MicroSD) using a pre-built u-boot binary from the website.
Are you running from USB power or a DC supply? There are some USB cables that have poor wiring and can cause issues with stability. Try another USB cable and/or try a DC supply. The DC supply connector is a 2.1mm x 5.5mm jack.
Yes, unfortunately it seems you are right.
Can you send Oops messages from the boot crashes? Then we can check if the issue(s) is/are already known.
or a
5.5mm jack.
I ran it USB powered with the cable that came with the board. I just tried it
using a stabilized lab power supply, but the result was more or less the same.
That's a good idea - just tried this but I did not connect audio and s-video (I
don't think I own an NTSC capable device). I ran the test three times trying USB
and DC supply. One time it crashed quite fast, two times it booted into the test
filesystem. I was able to run the video playback test, but the board froze after
a few seconds.
No I don't think I suffer from this. I get the same behavior with the validation
set of binary images and here the device never survived longer than three
minutes. In about 20% to 30% of all boot attempts it did not even reach userspace.
