Below is picture of the display on bootup. Expected display output is overwritten by Angstrom screen
Expected Display output
The expected display output briefly appears but is overwritten by the Angstrom text based image. But occasionally the expected display appears. Then the dynamic widgets update the screen but the static information is not visible. The issues appears to be timing, and if the BBB can be forced to start the QT application after complete bootup of BBB that would suffices the current needs.
Application is been started as a service. Below is the content of the service file
[Unit]
Description=QTAccelerometer GUI
After=systemd-user-sessions.service
[Service]
WorkingDirectory=/home/root/projects/qt-projects
ExecStart=/home/root/projects/qt-projects/QTAccelerometer -qws
SyslogIdentifier=QTAccelerometer
Restart=on-failure
RestartSec=5
[Install]
Alias=display-manager.service
Below are the other options tried without success
[Install]
WantedBy=multi-user.target
WantedBy=graphical.target
References
Creating Ångström System Services on BeagleBone Black
I have also posted this question on Stackoverflow.
Thank you in advance
Mahen
