Hi All.
I have a usecase for using BeagleY-AI in a Kiosk environment, but will need to utilize hardware accelerated Firefox in order for smooth user experience.
I remember reading in the early days of BBY-AI that Firefox wasn’t using GPU…evidently there was an experimental build somewhere that @RobertCNelson mentioned, but unsure of what the current status is?
Is this now working in main distro?
Our ‘cinnamon’ images had working acceleration thru wayland and it works thru firefox. (3d acceleration)…
Haven’t tested it in a while.
RobertCNelson:
cinnamon
I can’t find that on /distros page?
it wasn’t that useful, Cinnamon 6.2 (with wayland) was badly broken… The only thing that worked, was to start firefox, search quake webgl…
here’s some weekly builds, Index of /rootfs/debian-arm64-12-bookworm-cinnamon-v6.1-ti but it’s probally broken as i pushed mesa 25.0.0 the other day to the default so i need to update the fake version for ti’s build… (fixed: https://openbeagle.org/beagleboard/ci-mesa-sgx-24.0/-/commit/99a7891aa17e695e957f86684a756cb46deecbae ) ( waiting: pages (#54776) · Jobs · BeagleBoard.org / ci-mesa-sgx-24.0 · GitLab )
Package build finished, triggering a fresh image rebuild…
and uploading as we type: Index of /rootfs/debian-arm64-12-bookworm-cinnamon-v6.1-ti/2025-03-17
edit, (that version of mesa is for v6.12.x) so let’s try this again: ci: bump mesa 25.1.0 (08d67aa9) · Commits · BeagleBoard.org / ci-mesa-sgx-23.3 · GitLab and building ( pages (#54812) · Jobs · BeagleBoard.org / ci-mesa-sgx-23.3 · GitLab )
okay finished again, triggered a new image build.
Okay this looks better…
The following packages will be upgraded:
libegl-mesa0 libgbm-dev libgbm1 libgl1-mesa-dri libglapi-mesa libglx-mesa0
libosmesa6 libosmesa6-dev
8 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 30.3 MB of archives.
After this operation, 140 MB of additional disk space will be used.
Get:1 http://debian.beagleboard.org/arm64 bookworm/main arm64 libllvm16 arm64 1:16.0.6-19 [20.6 MB]
Get:2 https://beagleboard.beagleboard.io/ci-mesa-sgx-23.3 stable/main arm64 libglapi-mesa arm64 25.1.0-0.git54812~bookworm [45.4 kB]
Get:3 https://beagleboard.beagleboard.io/ci-mesa-sgx-23.3 stable/main arm64 libgl1-mesa-dri arm64 25.1.0-0.git54812~bookworm [6726 kB]
Get:4 https://beagleboard.beagleboard.io/ci-mesa-sgx-23.3 stable/main arm64 libgbm-dev arm64 25.1.0-0.git54812~bookworm [19.6 kB]
Get:5 https://beagleboard.beagleboard.io/ci-mesa-sgx-23.3 stable/main arm64 libegl-mesa0 arm64 25.1.0-0.git54812~bookworm [112 kB]
Get:6 https://beagleboard.beagleboard.io/ci-mesa-sgx-23.3 stable/main arm64 libgbm1 arm64 25.1.0-0.git54812~bookworm [39.8 kB]
Get:7 https://beagleboard.beagleboard.io/ci-mesa-sgx-23.3 stable/main arm64 libglx-mesa0 arm64 25.1.0-0.git54812~bookworm [146 kB]
Get:8 https://beagleboard.beagleboard.io/ci-mesa-sgx-23.3 stable/main arm64 libosmesa6-dev arm64 25.1.0-0.git54812~bookworm [18.9 kB]
Get:9 https://beagleboard.beagleboard.io/ci-mesa-sgx-23.3 stable/main arm64 libosmesa6 arm64 25.1.0-0.git54812~bookworm [2570 kB]
Okay new version is being uploaded, make sure the time is 2025-03-17 16:42 while the 2025-03-17 14:29 gets overridden by rsync…
https://rcn-ee.net/rootfs/debian-arm64-12-bookworm-cinnamon-v6.1-ti/2025-03-17/
Thanks for this @RobertCNelson
This may be a silly question, but why is this only available with Cinnamon desktop? Why couldnt hardware accelerated firefox work in main distro?
Hi, same problem. Were you successful? Thx in advance.
Well, I did get the image @RobertCNelson linked to load. Also, I confirmed in firefox about:support that hardware acceleration was recognized. But the big problem I had was under about:support it list the individual codecs and whether or not they are using hardware/software rendering. Everything except H264 was using software…I assume this is a limitation of the TI GPU? I dont know.
So the end result was, unless you are specifically decoding H264 video, I’m not sure what benefit there would be?
I ran some test between Cinnamon version linked above and normal BBYAI distro and couldnt tell any meaningful difference in speed between the two firefoxes.
