Today, it looks like I’m able to load the example C66 DSP executable built under the TI SDK RTOS folder ipc_3_50_04_08/examples/DRA7XX_linux_elf/ex02_messageq and successfully run it. The other day I was getting remoteproc errors (-2) and a message indicating that the resource table was not found. I’m not sure what was going on, except the status of DSP1 was showing up as Offline instead of Running. I followed the instructions to transition DSP1 to the Running state, but it remained Offline.
Today, when I tried that same step, it transitioned from Suspended to Running.
Following are the steps I took to get the Linux app, built under the latest TI SDK Linux folder, exchanging messages with DSP1 (also built under the latest TI SDK).
root@beaglebone:/home/debian/ipc-starter/debug# cat /sys/kernel/debug/remoteproc/remoteproc*/name
4b234000.pru
4b238000.pru
4b2b4000.pru
4b2b8000.pru
58820000.ipu
55020000.ipu
40800000.dsp
41000000.dsp
root@beaglebone:/home/debian/ipc-starter/debug# cat /sys/class/remoteproc/remoteproc*/state
offline
offline
offline
offline
suspended
suspended
suspended
suspended
root@beaglebone:/home/debian/ipc-starter/debug# echo on > /sys/bus/platform/devices/40800000.dsp/power/control
offline
offline
offline
offline
suspended
suspended
running
suspended
root@beaglebone:/lib/firmware# mv dra7-dsp1-fw.xe66 dra7-dsp1-fw.xe66.stock_image
root@beaglebone:/lib/firmware# ln -s /home/debian/ipc-starter/debug/server_dsp1.xe66 dra7-dsp1-fw.xe66
cd /sys/bus/platform/drivers/omap-rproc/
root@beaglebone:/sys/bus/platform/drivers/omap-rproc# echo 40800000.dsp > unbind
[ 1952.619664] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[ 1952.619707] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[ 1952.621403] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[ 2449.430488] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[ 2449.430933] remoteproc remoteproc6: stopped remote processor 40800000.dsp
[ 2449.431164] remoteproc remoteproc6: releasing 40800000.dsp
root@beaglebone:/sys/bus/platform/drivers/omap-rproc# echo 40800000.dsp > bind
[ 2594.517030] omap-rproc 40800000.dsp: assigned reserved memory node dsp1-memory@99000000
[ 2594.517162] remoteproc remoteproc6: 40800000.dsp is available
[ 2594.532869] remoteproc remoteproc6: powering up 40800000.dsp
[ 2594.532890] remoteproc remoteproc6: Booting fw image dra7-dsp1-fw.xe66, size 4407080
[ 2594.539898] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[ 2594.539936] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[ 2594.540034] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[ 2594.545910] alloc_contig_range: [99000, 99003) PFNs busy
[ 2594.546343] alloc_contig_range: [99004, 99007) PFNs busy
[ 2594.546807] alloc_contig_range: [99000, 99003) PFNs busy
[ 2594.547230] alloc_contig_range: [99004, 99007) PFNs busy
[ 2594.556580] alloc_contig_range: [99600, 99700) PFNs busy
[ 2594.564388] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 2594.564464] remoteproc remoteproc6: registered virtio2 (type 7)
[ 2594.564474] remoteproc remoteproc6: remote processor 40800000.dsp is now up
[ 2594.565391] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x3d
root@beaglebone:/home/debian/ipc-starter/debug# ./app_host -l
→ main:
Processor List
procId=0, procName=HOST
procId=1, procName=IPU2
procId=2, procName=IPU1
procId=3, procName=DSP2
procId=4, procName=DSP1
root@beaglebone:/home/debian/ipc-starter/debug# ./app_host DSP1
→ main:
→ Main_main:
→ App_create:
App_create: Host is ready
← App_create:
→ App_exec:
App_exec: sending message 1
App_exec: sending message 2
App_exec: sending message 3
App_exec: message received, sending message 4
App_exec: message received, sending message 5
App_exec: message received, sending message 6
App_exec: message received, sending message 7
App_exec: message received, sending message 8
App_exec: message received, sending message 9
App_exec: message received, sending message 10
App_exec: message received, sending message 11
App_exec: message received, sending message 12
App_exec: message received, sending message 13
App_exec: message received, sending message 14
App_exec: message received, sending message 15
← App_exec: 0
→ App_delete:
← App_delete:
← Main_main:
← main:
root@beaglebone:/home/debian/ipc-starter/debug# uname -a
Linux beaglebone 4.14.108-ti-r131 #1buster SMP PREEMPT Tue Mar 24 19:18:36 UTC 2020 armv7l GNU/Linux
root@beaglebone:/home/debian/ipc-starter/debug# cat /etc/dogtag
BeagleBoard.org Debian Buster IoT TIDL Image 2020-04-06
Also, I tried this same example on the latest SDK image built from the pre-built binaries:
← main:
root@am57xx-evm:~/ipc-starter# ./app_host -l
→ main:
Processor List
[ 1623.665988] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
[ 1623.703839] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[ 1623.710423] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[ 1623.717147] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[ 1623.724224] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
root@am57xx-evm:~/ipc-starter# ./app_host DSP1
→ main:
[ 1636.665992] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
[ 1636.703878] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[ 1636.710490] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[ 1636.717216] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[ 1636.724309] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
→ Main_main:
→ App_create:
← App_create:
→ App_exec:
← App_exec: 0
→ App_delete:
← App_delete:
← Main_main:
← main:
For building the TI SDK RTOS examples (IMU, DSP, host), and for instructions on how to get the Linux host to load and run the exe’s, I followed this:http://software-dl.ti.com/processor-sdk-linux/esd/docs/latest/linux/Foundational_Components_IPC.html#ipc-for-am57xx
As I get additional results worth posting, I’ll do so. I THINK my next-steps are to learn how to build SDK RTOS DSP images with the resource table, and then load and debug via CCS.
like DSP and hard realtime and CCS source level debug of RTOS and bare bones using JTAG and C6xx binary support and best off documented explanations of the IPC memory layout. Dropping binaries on Linux is not a skill set I want on my resume and I expect documents. ASK is my solution
