1. my SD card must be somewhat right because
I can now boot all the way to Angstrom desktop
and it shows the kernel version (3.017) I expected.
I consider this a big victory but it comes at a cost...
What doesn't work:
1. I can't get to u-boot prompt at all. I hit keys
like crazy during the "stop autoboot" countdown
and it ignores them and keeps booting. (To be
fair: I occasionally saw this with the BB fresh out
of the box.)
2. Without the SD card plugged in, board still
appears "bricked." (As per previous post.)
3. As per previous post, output from BB console
port (accessed via uart and terminal emulator)
ceases just after this message: "Uncompressing
Linux... done, booting the kernel."
What doesn't work:
of the box.)
Check your serial cabling, being able to see messages
but not send is a very prominent error case when
using the wrong cabling
yes, you deleted the NAND content, it will appear
so, don't worry.
I guess you don't set up the correct console,
thus you dont see linux console log messages.
I consider this a big victory but it comes at a cost…
What doesn’t work:
I can’t get to u-boot prompt at all. I hit keys
like crazy during the “stop autoboot” countdown
of the box.)
The cabling worked fine until the moment I started messing with the u-boot environment. In fact, it had to have worked in order for me to enter commands at the u-boot prompt, thereby messing up the u-boot environment.
appears “bricked.” (As per previous post.)
so, don’t worry.
What do I need to do so that I boot again without the SD card present?
ceases just after this message: “Uncompressing
Linux… done, booting the kernel.”
I guess you don’t set up the correct console,
I am using ‘cu’, to wit:
cu -l ttyS0 -s 115200
This works fine (most of the time.) Can you suggest a more appropriate terminal emulator to use? (my host system runs Ubuntu 11.10.)
