I am trying to decipher my strace. My setup is Linux beaglebone 4.1.12-ti-r29 #1 SMP PREEMPT Mon Nov 9 22:46:19 UTC 2015 armv7l GNU/Linux BeagleBoard.org Debian Image 2015-11-12. I am not sure on how to interpet my findings. In particular of the files that are missing is that because I need an update or do they arise out a make file that simply is not working or incorrect. The CMake version that I am using is 3.0.2. Thanks for replies in advance.
execve("./LCDApp", ["./LCDApp"], [/* 19 vars */]) = 0
brk(0) = 0x4bf000
uname({sys=“Linux”, node=“beaglebone”, …}) = 0
access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory)
mmap2(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6f95000
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=26752, …}) = 0
mmap2(NULL, 26752, PROT_READ, MAP_PRIVATE, 3, 0) = 0xb6f8e000
close(3) = 0
open("/lib/arm-linux-gnueabihf/tls/v7l/neon/vfp/libEBBLibrary.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/arm-linux-gnueabihf/tls/v7l/neon/vfp", 0xbea01370) = -1 ENOENT (No such file or directory)
open("/lib/arm-linux-gnueabihf/tls/v7l/neon/libEBBLibrary.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/arm-linux-gnueabihf/libEBBLibrary.so", O_RDONLY|O_CLOEXEC) = 3
read(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0`m\0\0004\0\0\0”…, 512) = 512
lseek(3, 95252, SEEK_SET) = 95252
read(3, “\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0”…, 1200) = 1200
lseek(3, 63425, SEEK_SET) = 63425
read(3, “A2\0\0\0aeabi\0\1(\0\0\0\0057-A\0\6\n\7A\10\1\t\2\n\4\22”…, 51) = 51
fstat64(3, {st_mode=S_IFREG|0755, st_size=96452, …}) = 0
mmap2(NULL, 128964, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6f50000
mprotect(0xb6f5f000, 65536, PROT_NONE) = 0
mmap2(0xb6f6f000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xf000) = 0xb6f6f000
close(3) = 0
open("/usr/lib/arm-linux-gnueabihf/libstdc++.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, “\177ELF\1\1\1\3\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0 n\4\0004\0\0\0”…, 512) = 512
close(3) = 0
lseek(3, 100684, SEEK_SET) = 100684
read(3, “\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0”…, 1520) = 1520
lseek(3, 65940, SEEK_SET) = 65940
read(3, “A4\0\0\0aeabi\0\1*\0\0\0\0057-A\0\6\n\7A\10\1\t\2\n\4\22”…, 53) = 53
fstat64(3, {st_mode=S_IFREG|0755, st_size=102204, …}) = 0
mmap2(NULL, 139836, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6ceb000
mprotect(0xb6cfb000, 61440, PROT_NONE) = 0
mmap2(0xb6d0a000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xf000) = 0xb6d0a000
mmap2(0xb6d0c000, 4668, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xb6d0c000
close(3) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6f8c000
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6f8b000
set_tls(0xb6f8b4c0, 0xb6f98050, 0xb6f8bbb8, 0xb6f8b4c0, 0xb6f98050) = 0
mprotect(0xb6df6000, 8192, PROT_READ) = 0
mprotect(0xb6d0a000, 4096, PROT_READ) = 0
mprotect(0xb6e97000, 4096, PROT_READ) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6f8a000
mprotect(0xb6f44000, 16384, PROT_READ) = 0
mprotect(0xb6f97000, 4096, PROT_READ) = 0
munmap(0xb6f8e000, 26752) = 0
set_tid_address(0xb6f8b068) = 650
set_robust_list(0xb6f8b070, 12) = 0
rt_sigaction(SIGRTMIN, {0xb6cefd9d, [], SA_RESTORER|SA_SIGINFO, 0xb6d34ae1}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {0xb6cefcbd, [], SA_RESTORER|SA_RESTART|SA_SIGINFO, 0xb6d34ae1}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM_INFINITY}) = 0
futex(0xb6f4ece8, FUTEX_WAKE_PRIVATE, 2147483647) = 0
futex(0xb6f4ecdc, FUTEX_WAKE_PRIVATE, 2147483647) = 0
fstat64(1, {st_mode=S_IFCHR|0600, st_rdev=makedev(136, 0), …}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6f94000
write(1, “Starting EBB LCD Character Displ”…, 43) = 43
brk(0) = 0x4bf000
brk(0x4e0000) = 0x4e0000
open("/dev/spidev2.0", O_RDWR) = -1 ENOENT (No such file or directory)
dup(2) = 3
fcntl64(3, F_GETFL) = 0x402 (flags O_RDWR|O_APPEND)
fstat64(3, {st_mode=S_IFCHR|0600, st_rdev=makedev(136, 0), …}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6f93000
_llseek(3, 0, 0xbea01838, SEEK_CUR) = -1 ESPIPE (Illegal seek)
write(3, “SPI: Can’t open device.: No such”…, 51) = 51
close(3) = 0
munmap(0xb6f93000, 4096) = 0
ioctl(-1, 0x40046b04, 0x4bf024) = -1 EBADF (Bad file descriptor)
dup(2) = 3
_llseek(3, 0, 0xbea01968, SEEK_CUR) = -1 ESPIPE (Illegal seek)
write(3, “SPI: Can’t set max speed HZ: Bad”…, 49) = 49
lose(3) = 0
ioctl(-1, 0x40206b00, 0xbea01a30) = -1 EBADF (Bad file descriptor)
dup(2) = 3
_llseek(3, 0, 0xbea01910, SEEK_CUR) = -1 ESPIPE (Illegal seek)
write(3, “SPI: SPI_IOC_MESSAGE Failed: Bad”…, 49) = 49
close(3) = 0
