After downloading the latest image ( bbx15-debian-9.3-lxqt-armhf-2018-01-28-4gb.img.xz) for the BB-X15 from http://beagleboard.org/latest-images, verifying the sha256, and ripping an SD card via Win32DiskImager (Etcher hangs on the verify step for some reason):
My console on my 572xEVM Rev A3 shows the following:
U-Boot SPL 2017.01-00360-gc604741cb3 (Aug 11 2017 - 15:47:09)
DRA752-GP ES2.0
Trying to boot from MMC1
** Unable to use mmc 0:1 for loading the env **
Using default environment
U-Boot 2017.01-00360-gc604741cb3 (Aug 11 2017 - 15:47:09 -0500), Build: jenkins-github_Bootl2
CPU : DRA752-GP ES2.0
Model: TI AM5728 BeagleBoard-X15
Board: AM572x EVM REV A.3A
DRAM: 2 GiB
setup_board_eeprom_env: am57xx_evm_reva3
SCSI: SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices…
Found 0 device(s).
cpsw
Press SPACE to abort autoboot in 2 seconds
usb_boot is currently disabled
scsi_boot is currently disabled
switch to partitions #0, OK
mmc0 is current device
Scanning mmc device 0
Checking for: /uEnv.txt …
Checking for: /boot/uEnv.txt …
445 bytes read in 24 ms (17.6 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt …
debug: [uname_r=4.9.78-ti-r94] …
loading /boot/vmlinuz-4.9.78-ti-r94 …
9960536 bytes read in 456 ms (20.8 MiB/s)
loading /boot/dtbs/4.9.78-ti-r94/am57xx-evm-reva3.dtb …
155403 bytes read in 127 ms (1.2 MiB/s)
loading /boot/initrd.img-4.9.78-ti-r94 …
6300596 bytes read in 292 ms (20.6 MiB/s)
debug: [console=ttyO2,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool.
debug: [bootz 0x82000000 0x88080000:6023b4 0x88000000] …
Loading Ramdisk to 8f9fd000, end 8ffff3b4 … OK
Loading Device Tree to 8f9d4000, end 8f9fcf0a … OK
Starting kernel …
[ 0.073146] /cpus/cpu@0 missing clock-frequency property
[ 0.073171] /cpus/cpu@1 missing clock-frequency property
[ 2.448629] dra7-pcie 51000000.pcie: phy link never came up
[ 2.710443] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 2.726129] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 2.838825] omap_voltage_late_init: Voltage driver support not added
[ 3.512258] omap_hsmmc 4809c000.mmc: card busy
[ 3.561793] mmc0: error -110 whilst initialising SD card
Gave up waiting for root file system device. Common problems:
- Boot args (cat /proc/cmdline)
- Check rootdelay= (did the system wait long enough?)
- Missing modules (cat /proc/modules; ls /dev)
ALERT! /dev/mmcblk0p1 does not exist. Dropping to a shell!
BusyBox v1.22.1 (Debian 1:1.22.0-19+b3) built-in shell (ash)
Enter ‘help’ for a list of built-in commands.
(initramfs)
?? Is this maybe a pinmux issue with MMC0 in the dev. tree ??
Is anyone else having the same issue?
