I ma trying to boot BBB from Sd Card But It always stuck at “Starting kernel …”
MLO, u-boot.img, uEnv.txt, am335x-boneblack.dtb are paced in BOOT partation of sdcard.
MLO, u-boot.img ---->> created by u-boot
rootfs.ext4 ---->> created by build-root
uImage ---->> linux-6.9.9
uEnv.txt
console=ttyS0,115200n8
ipaddr=192.168.7.2
serverip=192.168.7.1
loadaddr=0x82000000
fdtaddr=0x88080000
netargs=echo Setting netargs from uEnv.txt ...; setenv bootargs console={console} root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait debug earlyprintk mem=512M
netboot=echo Booting/Loading netboot from microSD ...; load mmc 0:1 ${loadaddr} uImage ; load mmc 0:1 ${fdtaddr} am335x-boneblack.dtb
uenvcmd=setenv autoload no ; run netboot; run netargs; bootm ${loadaddr} - ${fdtaddr}
minicom Log
U-Boot SPL 2015.10-00001-g143c9ee (Nov 06 2015 - 15:27:19)
bad magic
U-Boot 2015.10-00001-g143c9ee (Nov 06 2015 - 15:27:19 -0600), Build: jenkins-github_Bootloader-Builder-274
Watchdog enabled
I2C: ready
DRAM: 512 MiB
Reset Source: Global external warm reset has occurred.
Using default environment
Net: <ethaddr> not set. Validating first E-fuse MAC
cpsw
switch to partitions #0, OK
mmc0 is current device
Checking for: /uEnv.txt ...
reading uEnv.txt
475 bytes read in 4 ms (115.2 KiB/s)
Importing environment from mmc ...
Checking if uenvcmd is set ...
Running uenvcmd ...
reading uImage
5281496 bytes read in 289 ms (17.4 MiB/s)
reading am335x-boneblack.dtb
86904 bytes read in 11 ms (7.5 MiB/s)
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Linux-6.9.9
Created: 2024-07-20 17:32:47 UTC
Data Size: 5281432 Bytes = 5 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 88080000
Booting using the fdt blob at 0x88080000
Loading Kernel Image ... OK
Loading Device Tree to 8ffe7000, end 8ffff377 ... OK
Starting kernel ...
I again Cross checked it.
It still stuck at the part.
FYI…
Checking for: /uEnv.txt …
reading uEnv.txt
481 bytes read in 3 ms (156.3 KiB/s)
Checking if uenvcmd is set …
Running uenvcmd …
Booting/Loading netboot from microSD …
reading uImage
5281496 bytes read in 288 ms (17.5 MiB/s)
Setting netargs from uEnv.txt …
Booting kernel from Legacy Image at 82000000 …
Verifying Checksum … OK
Loading Kernel Image … OK
Loading Device Tree to 8ffe7000, end 8ffff377 … OK
If you built MLO/u-boot.img, why does it have my build info: 2015.10-00001-g143c9ee (Nov 06 2015), so your not using your MLO/u-boot.img (erase the eMMC or hold the usr button) on bootup to force the microSD to be used…
I am booting from sd card , and I am not pressing S2 button because what I saw in serial logs it first attempt to boot from mmc0(sd card) if that is not successfully done then it switch to mmc1(MMC) .
if your booting with a newer u-boot on sdcard and the boot log shows 2015 u-boot, then it is using the one in emmc. if you have no reason to keep whats in emmc, ya might want to dd zero to the emmc, this will make the boot from sd card.
Now I am getting issue with “Loading Kernel Image … Image too large: increase CONFIG_SYS_BOOTM_LEN”
Watchdog enabled
I2C: ready
DRAM: 512 MiB
Reset Source: Global warm SW reset has occurred.
cpsw
reading uEnv.txt
Running uenvcmd ...
reading uImage
20316736 bytes read in 1094 ms (17.7 MiB/s)
reading am335x-evm.dtb
65859 bytes read in 9 ms (7 MiB/s)
## Booting kernel from Legacy Image at 80008000 ...
Image Name: Linux-5.10.162-cip24
Created: 2024-07-24 19:52:42 UTC
Data Size: 20316672 Bytes = 19.4 MiB
## Flattened Device Tree blob at 88000000
Loading Kernel Image ... Image too large: increase CONFIG_SYS_BOOTM_LEN
Must RESET board to recover
resetting ...
bad magic
started to reproduce your work today, using latest buildroot (did not see above what version your using)
did use your config with same cross compile stuff. it built ok
download u-boot from the link you provided, using the config you provided, it build ok
next;
Linux-6.9.9
where did you get this from?? is this from main line?? and can you provide your config file for it.
more than happy to help out, reproducing your build is the key.
Yes, I got it from main line.
config file: omap2plus_defconfig
buildroot version:
# Set and export the version string
export BR2_VERSION := 2024.08-git
# Actual time the release is cut (for reproducible builds)
BR2_VERSION_EPOCH = 1718188000
# Save running make version since it's clobbered by the make package
RUNNING_MAKE_VERSION := $(MAKE_VERSION)
# Check for minimal make version (note: this check will break at make 10.x)
MIN_MAKE_VERSION = 3.81
using a rootfs from Buildroot 2023.08 (only because i have an image)
for buildroot 2024.08, i’ll need to do more work, but it should work also
replaced MLO and u-boot.img built from 2024.10 (the link you provided, master branch)
BBB booted ok
then replaced zImage and am335x-boneblack.dtb built from linux-6.9.11
BBB booted ok
boot log for new u-boot and zImage is attached. linux_boot.log (22.4 KB)
