Update : it worked thanks a lot @RobertCNelson
Just now i hardly manage to log in console serial, and no hdmi output, what does this mean, are all of these problems related to the dtb file ? and also im in debian 8, is it ok to be in debian 8 for kernel 6 ? thanks
[ 46.100661] uio: section 4 reloc 9 sym ‘sprintf’: relocation 30 out of range (0xbfac7060 → 0xc0ad927d)
[ 46.161809] tps65217_charger: section 4 reloc 29 sym ‘__stack_chk_fail’: relocation 10 out of range (0xbfad515c → 0xc0aeb131)
[ OK ] Started Login Service.
[ 46.377445] uio: section 4 reloc 16 sym ‘__stack_chk_fail’: relocation 10 out of range (0xbfae30e0 → 0xc0aeb131)
Starting LSB: set CPUFreq kernel parameters…
[ 46.718350] uio_pdrv_genirq: section 4 reloc 16 sym ‘of_property_read_string’: relocation 10 out of range (0xbf80011a → 0xc0928b75)
[ 46.852085] uio_pdrv_genirq: section 4 reloc 16 sym ‘of_property_read_string’: relocation 10 out of range (0xbf80e11a → 0xc0928b75)
[ OK ] Started LSB: set CPUFreq kernel parameters.
[ 47.158764] uio_pdrv_genirq: section 4 reloc 16 sym ‘of_property_read_string’: relocation 10 out of range (0xbf81c11a → 0xc0928b75)
[ 47.233632] evdev: section 4 reloc 2 sym ‘mutex_lock’: relocation 10 out of range (0xbf82a070 → 0xc0aed9ed)
[ 47.285752] uio_pdrv_genirq: section 4 reloc 16 sym ‘of_property_read_string’: relocation 10 out of range (0xbf83811a → 0xc0928b75)
[ 47.416277] uio_pdrv_genirq: section 4 reloc 16 sym ‘of_property_read_string’: relocation 10 out of range (0xbf84611a → 0xc0928b75)
[ 47.546629] uio_pdrv_genirq: section 4 reloc 16 sym ‘of_property_read_string’: relocation 10 out of range (0xbf85411a → 0xc0928b75)
[ 47.701463] rng_core: section 4 reloc 10 sym ‘warn_slowpath_fmt’: relocation 10 out of range (0xbf862064 → 0xc0adc7e5)
[ 47.827059] uio_pdrv_genirq: section 4 reloc 16 sym ‘of_property_read_string’: relocation 10 out of range (0xbf87011a → 0xc0928b75)
[ 47.963246] uio_pdrv_genirq: section 4 reloc 16 sym ‘of_property_read_string’: relocation 10 out of range (0xbf87e11a → 0xc0928b75)
[ 48.179955] uio_pdrv_genirq: section 4 reloc 16 sym ‘of_property_read_string’: relocation 10 out of range (0xbf88c11a → 0xc0928b75)
[ 48.344931] uio_pdrv_genirq: section 4 reloc 16 sym ‘of_property_read_string’: relocation 10 out of range (0xbf89a11a → 0xc0928b75)
[ 48.489329] uio_pdrv_genirq: section 4 reloc 16 sym ‘of_property_read_string’: relocation 10 out of range (0xbf8a811a → 0xc0928b75)
[ 48.596355] uio_pdrv_genirq: section 4 reloc 16 sym ‘of_property_read_string’: relocation 10 out of range (0xbf8b611a → 0xc0928b75)
[ 48.739387] uio_pdrv_genirq: section 4 reloc 16 sym ‘of_property_read_string’: relocation 10 out of range (0xbf8c411a → 0xc0928b75)
[ 48.856030] uio_pdrv_genirq: section 4 reloc 16 sym ‘of_property_read_string’: relocation 10 out of range (0xbf8d211a → 0xc0928b75)
[ 49.121085] uio_pdrv_genirq: section 4 reloc 16 sym ‘of_property_read_string’: relocation 10 out of range (0xbf8e011a → 0xc0928b75)
[ 49.236114] uio_pdrv_genirq: section 4 reloc 16 sym ‘of_property_read_string’: relocation 10 out of range (0xbf8ee11a → 0xc0928b75)
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
SA31SA31 login: login: [ 125.756532] export_store: invalid GPIO 62
[ 125.777473] export_store: invalid GPIO 45
[ 125.792748] export_store: invalid GPIO 23
[ 125.810694] export_store: invalid GPIO 34
[ 125.823926] export_store: invalid GPIO 22
[ 125.844506] export_store: invalid GPIO 36
[ 125.860288] export_store: invalid GPIO 44
[ 125.870031] export_store: invalid GPIO 61
[ 125.889165] export_store: invalid GPIO 114
[ 127.022378] FAT-fs (mmcblk0p2): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 127.161626] x_tables: section 4 reloc 9 sym ‘mutex_unlock’: relocation 30 out of range (0xbf92008e → 0xc0aecfa9)
[ 127.199983] x_tables: section 4 reloc 9 sym ‘mutex_unlock’: relocation 30 out of range (0xbf93808e → 0xc0aecfa9)
[ 127.239650] x_tables: section 4 reloc 9 sym ‘mutex_unlock’: relocation 30 out of range (0xbf95008e → 0xc0aecfa9)
[ 127.282507] x_tables: section 4 reloc 9 sym ‘mutex_unlock’: relocation 30 out of range (0xbf96808e → 0xc0aecfa9)
[ 127.327164] x_tables: section 4 reloc 9 sym ‘mutex_unlock’: relocation 30 out of range (0xbf98008e → 0xc0aecfa9)
[ 127.368864] x_tables: section 4 reloc 9 sym ‘mutex_unlock’: relocation 30 out of range (0xbf99808e → 0xc0aecfa9)
[ 127.408477] x_tables: section 4 reloc 9 sym ‘mutex_unlock’: relocation 30 out of range (0xbf9b008e → 0xc0aecfa9)
[ 127.447274] x_tables: section 4 reloc 9 sym ‘mutex_unlock’: relocation 30 out of range (0xbf9c808e → 0xc0aecfa9)
[ 127.491140] x_tables: section 4 reloc 9 sym ‘mutex_unlock’: relocation 30 out of range (0xbf9e008e → 0xc0aecfa9)
[ 127.538374] x_tables: section 4 reloc 9 sym ‘mutex_unlock’: relocation 30 out of range (0xbf9f808e → 0xc0aecfa9)
[ 127.575858] x_tables: section 4 reloc 9 sym ‘mutex_unlock’: relocation 30 out of range (0xbfa1008e → 0xc0aecfa9)
[ 127.607826] x_tables: section 4 reloc 9 sym ‘mutex_unlock’: relocation 30 out of range (0xbfa2808e → 0xc0aecfa9)
[ 127.640705] x_tables: section 4 reloc 9 sym ‘mutex_unlock’: relocation 30 out of range (0xbfa4008e → 0xc0aecfa9)
[ 127.672785] x_tables: section 4 reloc 9 sym ‘mutex_unlock’: relocation 30 out of range (0xbfa5808e → 0xc0aecfa9)
[ 127.705208] x_tables: section 4 reloc 9 sym ‘mutex_unlock’: relocation 30 out of range (0xbfa7008e → 0xc0aecfa9)
[ 127.736939] x_tables: section 4 reloc 9 sym ‘mutex_unlock’: relocation 30 out of range (0xbfa8808e → 0xc0aecfa9)
[ 127.769775] x_tables: section 4 reloc 9 sym ‘mutex_unlock’: relocation 30 out of range (0xbfaa008e → 0xc0aecfa9)
[ 127.802776] x_tables: section 4 reloc 9 sym ‘mutex_unlock’: relocation 30 out of range (0xbfab808e → 0xc0aecfa9)
[ 127.858600] x_tables: section 4 reloc 9 sym ‘mutex_unlock’: relocation 30 out of range (0xbfad008e → 0xc0aecfa9)
[ 127.894921] x_tables: section 4 reloc 9 sym ‘mutex_unlock’: relocation 30 out of range (0xbfae208e → 0xc0aecfa9)
[ 127.950178] ip_tables: section 4 reloc 3 sym ‘nf_unregister_net_hooks’: relocation 30 out of range (0xbf800026 → 0xc09ccee1)
[ 128.004474] ip_tables: section 4 reloc 3 sym ‘nf_unregister_net_hooks’: relocation 30 out of range (0xbf811026 → 0xc09ccee1)
[ 128.040263] ip_tables: section 4 reloc 3 sym ‘nf_unregister_net_hooks’: relocation 30 out of range (0xbf822026 → 0xc09ccee1)
[ 128.079457] ip_tables: section 4 reloc 3 sym ‘nf_unregister_net_hooks’: relocation 30 out of range (0xbf833026 → 0xc09ccee1)
[ 128.099255] ip_tables: section 4 reloc 3 sym ‘nf_unregister_net_hooks’: relocation 30 out of range (0xbf844026 → 0xc09ccee1)
[ 128.118876] ip_tables: section 4 reloc 3 sym ‘nf_unregister_net_hooks’: relocation 30 out of range (0xbf855026 → 0xc09ccee1)
[ 128.138730] ip_tables: section 4 reloc 3 sym ‘nf_unregister_net_hooks’: relocation 30 out of range (0xbf866026 → 0xc09ccee1)
[ 128.167255] ip_tables: section 4 reloc 3 sym ‘nf_unregister_net_hooks’: relocation 30 out of range (0xbf877026 → 0xc09ccee1)
[ 128.187125] ip_tables: section 4 reloc 3 sym ‘nf_unregister_net_hooks’: relocation 30 out of range (0xbf888026 → 0xc09ccee1)
[ 128.207700] ip_tables: section 4 reloc 3 sym ‘nf_unregister_net_hooks’: relocation 30 out of range (0xbf899026 → 0xc09ccee1)
[ 128.244772] ip_tables: section 4 reloc 3 sym ‘nf_unregister_net_hooks’: relocation 30 out of range (0xbf8aa026 → 0xc09ccee1)
[ 128.264693] ip_tables: section 4 reloc 3 sym ‘nf_unregister_net_hooks’: relocation 30 out of range (0xbf8bb026 → 0xc09ccee
[ 160.175116] xt_limit: section 4 reloc 12 sym ‘___ratelimit’: relocation 10 out of range (0xbf81c162 → 0xc0ad14a5)
[ 160.217708] xt_limit: section 4 reloc 12 sym ‘___ratelimit’: relocation 10 out of range (0xbf828162 → 0xc0ad14a5)
[ 160.260177] xt_limit: section 4 reloc 12 sym ‘___ratelimit’: relocation 10 out of range (0xbf834162 → 0xc0ad14a5)
[ 160.345962] xt_tcpudp: section 4 reloc 5 sym ‘skb_copy_bits’: relocation 10 out of range (0xbf8400ea → 0xc0959ed5)
[ 160.377482] xt_tcpudp: section 4 reloc 5 sym ‘skb_copy_bits’: relocation 10 out of range (0xbf84e0ea → 0xc0959ed5)
[ 160.406519] xt_tcpudp: section 4 reloc 5 sym ‘skb_copy_bits’: relocation 10 out of rang
here are the config file and dtb i used
.config (222,9 Ko)
am335x-boneblack.dtb (98,7 Ko)
am335x.dts (128,5 Ko)
