Subject: BeagleBone Black - All LEDs On
Hello, everyone.
I’m having an issue with my BeagleBone Black before it works but now all the LEDs are constantly illuminated, indicating a potential boot issue and it start like connecting and disconnecting from the laptop. Here’s what I’ve tried so far:
Device Details:
  • Model: BeagleBone Black
  • Power Supply: USB serial
  • OS Image Used:the standard version
Troubleshooting Steps Taken:
  1. **Re-flashed the eMMC with SD card **: I used Etcher and i also tried WIN32 to flash a fresh copy of the OS; verified the image was for the correct model i tried withh another SD card but while holding on S2 nothing happens no LEDs turn ON only the power LED .
  2. Connected via Serial Console: I used a USB port i changed the cable but nothing special. i tried to read data from the port with PTTY but i couldn’t.
  3. Boot from SD Card: Attempted booting from an SD card but while holding on S2 no LEDs turn On only the Power LED.
  4. Visual Inspection: Examined the board for visible damage—none found.
I’d appreciate any suggestions or insights into further steps I can take to troubleshoot and resolve this issue. Thank you!
It’s a little unclear what is ment by your step 2,
but unless it means you connected to the 6-pin debug header next to P9,
then that is what you should do next. Use a 3.3V USB-to-Serial adapter @ 115200,
heck even a Pi Debug Probe will get the job done.
Dump the output, attach to your post and we’ll take a look at it.
first Thank you for your response , when i connect my beagle USB-to-serial adapter I’m getting the following output during boot:
U-Boot SPL 2019.04-00002-g31a8ae0206 (May 13 2020 - 09:26:17 -0500)
Trying to boot from MMC2
Loading Environment from EXT4... mmc_read_data: timedout waiting for status!
omap_hsmmc_send_cmd: timedout waiting on cmd inhibit to clear
unable to select a mode
U-Boot 2019.04-00002-g31a8ae0206 (May 13 2020 - 09:26:17 -0500), Build: jenkins-github_Bootloader-Builder-139
CPU  : AM335X-GP rev 2.1
I2C:   ready
DRAM:  512 MiB
No match for driver 'omap_hsmmc'
Some drivers were not found
RTC 32KCLK Source: External.
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net:   eth0: MII MODE
cpsw, usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[A335BNLT] ...
board_rev=[00C0] ...
switch to partitions #0, OK
Scanning mmc 1:1...
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
2079 bytes read in 14 ms (144.5 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
** Invalid partition 2 **
** Invalid partition 3 **
** Invalid partition 4 **
** Invalid partition 5 **
** Invalid partition 6 **
** Invalid partition 7 **
starting USB...
USB0:   Port not available.
cpsw Waiting for PHY auto negotiation to complete......... TIMEOUT !
using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in
MAC 64:8c:bb:bc:2c:40
HOST MAC de:ad:be:af:00:00
RNDIS ready
The remote end did not respond in time.missing environment variable: pxeuuid
Retrieving file: pxelinux.cfg/01-64-8c-bb-bc-2c-40
RNDIS ready
The remote end did not respond in time.Retrieving file: pxelinux.cfg/C0A80102
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
The remote end did not respond in time.Retrieving file: pxelinux.cfg/default-arm-am33xx
RNDIS ready
RNDIS ready
RNDIS ready
The remote end did not respond in time.Config file not found
starting USB...
RNDIS ready
The remote end did not respond in time.cpsw Waiting for PHY auto negotiation to complete......... TIMEOUT !
RNDIS ready
The remote end did not respond in time.=>
Well, the good news is that your BBB isn’t entirely dead.
I can’t quite see if this dump is from an eMMC or the SD boot…
Could you try the S2 boot and see if it’s any different?
@RobertCNelson, what do you think?
Pro tip: Encapsulate dumps in tripple backticks ` ; it’ll make it soo much easier to read.
When i try to hold S2 button with SD card inserted i get : CCCCCCC
i tried uboot and used this commande ums 0 mmc 1 but it says Unknown command ‘ums’ - try ‘help’ // i think this command is not known in U-Boot version (2019.04)**
That’s a sign the flashing failed… We are seeing a lot of failures with etcher stable, just corrupting the microSD…
My last good version of etcher is 1.18.12 … Release v1.18.12 · balena-io/etcher · GitHub
Or you can use rpi-imager
thank you for your responce i really appreciat it
