Hello, are there any success stories of products made with a beaglebone?
In which area is beaglebone being used as a product? And what do you use it for?
I am successfully doing security penetration testing using multiple Beagles connected via Xbee/Zigbee networking from distances of up to a mile away.
I use the BBB and BB for nodes in a local Network to test out Cloud Computing Deployment and Management ideas.
I have Master/Slave DB servers and File systems that connect over several servers on my local network.
I also use BBB as a SSH jump Host for VPN access to Closed Networks.
The BB and BBB are great examples on Unix servers for many uses here in the Development Lab.
e.m.g.
http://myCloudWatcher.com/
Not really a commercial product, but still an appliance: I'm using one
of my Beaglebones as a server for RTL dongle. I can sit at my desktop
and access the receiver located in a place with better reception
conditions than where my computer is.
j.
I am thinking about an image processing application but i am not sure if it’s going to work well. I am going to use OPENCV for face recognition
We are using the BBB in our prototype home consumer electronics device. We built a custom cape and are using the BBB to drive it, process data, and wireless networking. The final device likely will not be a BBB (although may be based on am335x) but for rapid prototyping it has been great (and really cost-effective)
We have started using it as the next-generation embedded controller in our line of pulse generators and other laboratory instruments (http://www.avtechpulse.com/). It replaces a Z-World / Rabbit / Digi / whatever-they're-called-today RCM3200 embedded controller.
The BB controls the internal instrument functions, and also provides command communications via GPIB, RS-232, ssh, http (using shellinabox), telnet, and VXI-11. A custom shell provides a user console for the serial/ssh/shellinabox/telnet clients.
We've written a perl/linux VXI client, for anyone interested in such things: http://www.avtechpulse.com/options/vxi/client. VXI is really fantastic for avoiding the hell of GPIB drivers on linux.
It's been great using standard Linux tools to do this, compared to the very-limited and non-standard C tools provided with the RCM3200.
The main difficulties were stripping down the boot times to something reasonable for a benchtop instrument (they are ~8 seconds now, by tweaking the kernel compilation options), and providing safe shutdown (using FULL data+metadata journaling on the filesystem, with a supercap providing just enough time to cleanly use a magic sysrq to force the filesystem into readonly mode before shutdown).
The GPMC interface is great for providing high-speed parallel I/O, but boy, you sure have to read the manual to make that work.
We use Fedora as the distro.
- Mike
Interesting---how do you provide GPIB on BBB?
The GPMC bus connects to a National Instruments TNT4882 IC, with appropriate level translators. (The newer TNT5002 can probably be used without level translators).
- Mike
Hi mjc, did you find TNT4882 or TNT5002 for cheaper than $1040 as they are listed on NI’s site? Thanks,
-Andy
Mike…
Would you mind posting a few more details on the power-control solution using the supercap, along with information on how the magic sysrq is generated by the safe-shutdown hardware? Did you put the safe-shutdown hardware on a cape?
Are you running Fedora on the BBB? If you are, do you think it would be problematic to implement the fs journaling changes in Angstrom or Debian?
Mark
setting the ink zones on lithographic printers
