I have a 100% success connecting a 640x480 raw LCD panel via 1.8V to
3.3V level shifters using rev C board.
One remaining issue is that the video driver is using 24 bit color for
output since that is what the DVI connected display wants. My panel is
18 bits. I could rewire the video output bits in hardware 24 to 18
leaving some unconnected, but it's wasteful: I'd rather have extra i/o
lines on the J4/J5 connectors.
I can brute force OMAP video registers by using the regrw.ko driver
and then I can get proper 18 bit mapping, but this is ugly.
Is there an "official" way to switch the video driver to 18 bits? I
couldn't find any such parameter.
The 16 or 32 or whatever after resolution is NOT the same thing. The
depth of the frame buffer doesn't have to match the output.
Thanks.
Hi Alex,
I don't know if there is any official way to handle 18-bit, but in order to
move fast forward, I would just stay at 24-bit and do the rewiring as
suggested. In order to use the last 6 pins as GPIOs just change the
pin-muxing to GPIO-mode instead of the current DSS-mode and everything will
work out just fine. The DSS/DISPC module won't know that some of its signals
arent connected to any balls and you will be able to use the balls as
GPIOs...
Best regards - Good luck
Søren
