Sudo docker run -it ubuntu:latest
I am running Ubuntu Noble and having issues with running PicoRV Softcore so far…
Has anyone come across the issue of not allowing docker to run from Ubuntu Noble so that PicoRV Softcore cannot be used? It seems the instructions work and I have docker installed now but I cannot use the instructions listed here: How to use PicoRV Softcore on BeagleV-Fire — BeagleBoard Documentation
If anyone is having trouble so far with docker not working in this instruction set, please reply so I can move forward.
scratch that…I got it up and running now. I had to restart the docker .service file and .socket file.
Anyway, are there any good tutorials for booting the BeagleV-Fire? I have been having issues lately trying to boot the V-Fire into use cases…
debugger issue. No issue now (I think).
Off to make a build of artifacts and other ideas for building the image primarily.
Then, off to using the PWM and GPIO on the PolarFire SoC.
P.S. Posting will take place (hopefully). I will be all over it soon.
