Suggested Diagnostic Page Changes
Hello all,
I've recently received my Beagle Board and first want to issue a very big thanks to those involved. This board is a lot of fun.
I've gotten things up and running thanks to the diagnostics page (which i recommend for new users). It can be found here:
http://code.google.com/p/beagleboard/wiki/BeagleBoardDiagnostics
I would like to suggest a few changes to it however to help with clarity:
Under "Kernel Boots", # 3:
Currently it says:
Thank you for the input. I will get it into the next release of the System Reference Manual!
one short question: where can I get the source of stream_video?
2008/9/26 Gerald Coley <gerald@beagleboard.org>
I was under an impression that I had sources on wiki, thanks for
pointing out the missing file.
I have uploaded it here
http://beagleboard.googlecode.com/files/utDstream_tennis.c
I think this doesn't need the file name for argument as it has
hardcoded file name. Will check this out and update the wiki
accordingly.
Khasim
Hello Khasim,
thanks for your answer. I try to modify the file and to compile it. Of course there are missing header files (like omap24xxvout.h) Where can I download the SDK which contains the files necessary to compile utDstream_tennis.c?
Thank you and bye - Robert
2008/9/30 Syed Mohammed, Khasim <sm.khasim@gmail.com>
in case my mail did not reach the list: does nobody knows where I can get the necessary files like omap24xxvout.h?
Thanks in advance!
Robert
2008/10/7 Robert Kuhn <rowkajjh@googlemail.com>
just for the record. One does not need this header file. I can be replaced with
#define VIDIOC_G_OMAP2_ROTATION _IOR (ā€˜V’, 4, int)
I attach my demo which does not need a video but displays red and green :slight_smile:
Perhaps someone finds it usefull.
Bye - Robert
2008/10/9 Robert Kuhn <rowkajjh@googlemail.com>
utDstream_tennis.c (6.55 KB)
