The added power for the adapter is to provide extra power for the USB host,
when available on Rev C, and the expansion connector. It will easily run
from the USB supply. 500Ma is more than enough depending on what else you
decide to add to it. It takes roughly 350mA.
I might run it from the USB supply in the short term, but a dedicated
power regulator for it would free up a socket on the USB hub.
Most wall wart power supplies are not regulated, so it could be that
the listed supply is the best fit even though it can supply much more
power than is needed. I run my board off of a bench power supply and
the highest I have seen my board draw (outside of one issue) is 370mA
at 5V. The board is advertised as requiring 2W, which is 400mA at 5V,
and that is close to what I measured. The "outside issue" happened
when I tried to suspend to RAM: the board started drawing over 700mA
after the suspend failed.
Thats good, I've seen some power regulators that look like they might
work well that supply 500mA's, but I might look into a 1A power
regulator just in case something causes an above average drain on
power. Those current readings are they with something connected to the
USB socket or just powering the beagle board?
The regulator I was looking at initially (http://www.maplin.co.uk/
Module.aspx?ModuleNo=46473) supplies 5V +/-4% at 500mA's with a peak
output current of 700mA's. I might consider looking at (http://
www.maplin.co.uk/Module.aspx?ModuleNo=46475) a 1A regulator to cover
the eventuality of the beagle board drawing more power.
The main issue I would worry about for the car is the temperature
extremes. I have not looked at the rated temperature operating range
for the beagle board, but the OMAP3530 comes in a commercial package
that is rated for operating between 0C and 90C, and an industrial
package that is rated for operating between -40C and 105C. Obviously
the industrial part is much better suited for operating in a car.
There are other factors that go into figuring out the true temperature
operating range of a device besides the raw numbers in the datasheets,
and the calculations are not simple.
Thats something to think about, I'm hoping it would be ok, it would be
inside the passenger compartment of the car so shouldn't get too hot
or cold. I live in England so the temperature isn't too bad but does
dip a little below freezing in the winter. The temperature here
probably varies anywhere between -5C to 30C, but for most of the year
it's probably more like 15C. But I might be able to attach the beagle
board in such a way I could easily take it out if it's going to be
really cold. I'll give the specifications another look regarding
temperatures later.
Thanks for all the help, this groups been very useful and encouraging.
Daniel
