Supplying power to ESC
I purchased the following ESC: https://www.banggood.com/Racerstar-RS20Ax4-V2-20A-BB2-48MHz-Blheli_S-2-4S-Opto-Oneshot42-Multishot-4-in-1-ESC-for-FPV-Racer-p-1080541.html
It takes as input 2-4S. What’s the easiest way for me to connect the ESC straight to my Vbatt? I’ve tried driving it with the servo (+/-) pins, after enabling the servo, but the 6V isn’t sufficient, which I’ve also verified by supplying 6V directly from a power supply.
Should I use the LIPO pins available on the bottom of the board?
