Is there is anyway to use the Embest XDS 100v2 14 pin jtag for the beaglebone black,
i referred the difference for the 20pin and 14pin here: http://processors.wiki.ti.com/index.php/JTAG_Connectors
But any turnarounds to use this jtag in BBB which have the 20 pin connector.
Elavarasu.
You will need an adapter.
My Blackhawk USB100V2 came with a 14 pin to 20 pin CTI adapter. You can buy this separately, but it is expensive ($69), or you can make your own adapter.
John
Hi John,
Thanks for the reply…
“My Blackhawk USB100V2 came with a 14 pin to 20 pin CTI adapter. You can buy this separately, but it is expensive ($69), or you can make your own adapter.”
Is this one comes with that 14 to 20 pin connecotr…?
http://in.element14.com/texas-instruments/tmdsemu100v2u-20t/jtag-emulator-20pin-xds200-probe/dp/2396148
or
http://in.element14.com/texas-instruments/tmdsemu100v2u-14t/emulator-xds100-usb-jtag-14-pin/dp/1901880
It will be useful if you identify that…
Elavarasu.
Hi John,
or
Since the BBB has a 20pin CTI connector, buy the JTAG emulator with the 20pin connector. The one I have is:
http://www.blackhawk-dsp.com/products/USB100v2D.aspx
John
