Hi All,
I am trying to rule out SW issues with my BBB (HW Rev A5C) running Angstrom. First I am going to give a bit of background on when the issues started and then provide dumps of crashed as seen via UART.
BBB was working fine for quite some time.
Then I tried to switch from wired ethernet to wireless by plugging in UWN200 (http://www.logicsupply.com/components/networking/wireless/uwn200/) while BBB was powered by DC adapter.
My SSH over wired Ethernet froze.
I removed the UWN200 and rebooted a device but could not longer connect via SSH with wired ethernet
Connecting via USB (client) I could not get network connection to 192.168.7.2 either. As I realized later I did not even have usb0 listed when running ifconfig
At this point I connected via UART
I could see that the kernel was crashing with NULL pointer dereference Oops
Every few restarts it would get past this oops
I shutdown BBB and looked to upgrade to latest Angstrom a few days later, thinking maybe I am just a lucky one to hit a real bug in the kernel
I downloaded the following image https://s3.amazonaws.com/angstrom/demo/beaglebone/BBB-eMMC-flasher-2013.09.04.img.xz into SD card
BBB was booted from SD by holding the boot button.
Flashing process was problematic, it took a few reboots (about) from SD card for eMMC flashing to complete (4 solid LEDs) without kernel Oopsing
- One of the Oopses was odd as it was for “invalid instruction”
To me this feels like a HW problem due to failures manifesting themselves in different ways. Segfaults in the apps, NULL pointer dereferences in the kernel, Soft CPU lockups. But I would like to rule out a user error.
Few observations:
I have run mtest from uboot without any errors being detected
Same for memtester
Pressing rest button does not always reboot the device. Sometimes holding power button down is the only way to reboot the BBB. But sometimes it works just fine.
For a few reboots accessing BBB via HTTP would causes kernel Oopses. Trying it out just now and it worked just fine
The below is done post flashing to the latest angstrom:
- systemd once segfaulted during boot: http://pastebin.com/YFuxNs8e
- some times system boots just fine: http://pastebin.com/7HynL8H7
- “opkg upgrade” consistently segfaults
- “opkg install strace” consistently segfaults
Any suggestions on what I can do to narrow down the root cause of the issue would be greatly appreciated.
Thank you,
Vladimir
