As far as I can tell from u-boot, it probes the PHY asking for what
auto-negotiate abilities u-boot should use, then u-boot builds an
auto-negotiate "table" (of sorts) to do the auto-negotiation. u-boot
will print that info along with the result of auto-negotiation.
I don't see u-boot changing what ever the PHY was configured with.
For example, on a 100baseTX switch, I see:
Loading kernel from TFTP
cpsw Waiting for PHY auto negotiation to complete. done
link up on port 0, speed 100, full duplex
BOOTP broadcast 1
DHCP client bound to address 192.168.101.20
But, if I connect a beaglebone to a 10baseT device, u-boot will
output:
BOOTP broadcast 1
I've verified that the device on the other end of the Ethernet link
ethtool says and an auto-negotiating switch I have only lights the
10baseT light with my laptop set this way if I plug to the switch.
$ sudo ethtool eth1
Settings for eth1:
Supported ports: [ TP ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Speed: 10Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
Transceiver: internal
Auto-negotiation: on
MDI-X: Unknown
Supports Wake-on: pg
Wake-on: d
Current message level: 0x000000ff (255)
Link detected: yes
Might the SMSC PHY on the bone be performing auto-negotiation in
violation of its settings?
I'm not super familiar with Ethernet, but I do know that things
like wireshark won't let me see the auto-negotiation on the wire. I'm
curious to understand what's happening here as from my look though the
code I also don't see where u-boot changes the PHY settings to allow
for 10baseT auto-negotiation to work.
I'm considering hooking a scope up to an Ethernet cable and having a
look but I'm not sure how visible the auto-negotiation would be,
especially as triggering on it might be difficult.
Any thoughts?
I wonder if this has any connection to the SYS_RESETn duration being
too short for the PHY...
-Andrew
