Has anyone worked with SYS-BIOS on Beaglebone Black?
I’m sure many have. But have you booted it successfully using SD card?
If yes please share the problems you faced and steps you took to solve it.
I have executed Starterware codes successfully on BB Black but when I try booting SYS-BIOS related code using SD card it hangs and does not execute.
The problem I am sure is with the MLO file. It takes the default load address as 0x80000000 and start address also is the same.
Whereas in case of SYS-BIOS the start address needs to be different. Do I need to use a different MLO file?
