Flashing a new Debian image to the Beaglebone Black, it crashed due to a power outage.
After the incident, the Beaglebone does not boot (at boot time, the four LEDs stay lit), nor can be flashed.
Connecting to serial port, I can watch the boot logs and enter to U-Boot terminal.
The boot logs are:
U-Boot SPL 2014.04-00014-g47880f5 (Apr 22 2014 - 13:23:54)
reading args
spl_load_image_fat_os: error reading image args, err - -1
reading u-boot.img
reading u-boot.img
U-Boot 2014.04-00014-g47880f5 (Apr 22 2014 - 13:23:54)
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
cpsw, usb_ether
Card did not respond to voltage select!
mmc0(part 0) is current device
SD/MMC found on device 1
reading uEnv.txt
1590 bytes read in 6 ms (258.8 KiB/s)
Checking if uenvcmd is set …
Running uenvcmd …
reading zImage
7307264 bytes read in 453 ms (15.4 MiB/s)
reading initrd.img
** Unable to read file initrd.img **
reading /dtbs/am335x-boneblack.dtb
62752 bytes read in 15 ms (4 MiB/s)
Kernel image @ 0x82000000 [ 0x000000 - 0x758d58 ]
## Flattened Device Tree blob at 88000000
Using Device Tree in place at 88000000, end 8801251f
Starting kernel …
And here we have the four user LEDs lit.
The main issue seems to be the lack of the initrd.img file. Although, some other kernel files could be missed too.
Avoiding the option of having a hardware issue, I need to restore the kernel or a whole Linux image.
- Can it be done through serial port (as a kernel update)?
- Which is the best way to restore the Beaglebone?
KR!
