After installing Ubuntu 13.10 systemctl is not working. The file was the latest flsh image BBB-eMMC-flasher-ubuntu-13.10-2013-12-17-2gb
root@arm:~# uname -a
Linux arm 3.8.13-bone32 #1 SMP Fri Dec 13 20:05:25 UTC 2013 armv7l armv7l armv7l GNU/Linux
Can not start/stop services
root@arm:~# systemctrl
-bash: systemctrl: command not found
Please advise
OK
You are right. It is hard to switch from Angstrom to Ubuntu. Because I need some Ubuntu features
I switched from Angstrom and tried to duplicate ntp services configuration.
No, it's not working either
root@arm:~# systemctl
-bash: systemctl: command not found
In Ubuntu service is the command to use to start/stop/check services
root@arm:~# service
Usage: service < option > | --status-all | [ service_name [ command | --full-restart ] ]
