I ran into this again, after taking an SD card which worked on one board and loading it into a brand new board. Even after running the install script, I get tda driver errors and no screen.
@RobertCNelson do you have any ideas for me? Over UART, I can see that the BB-NHDMI-TDA998x-00A0.kernel overlay is loaded instead of any of the IT6612X overlays.
/boot/uEnv.txt:
uname_r=6.18.35-bone38
#uuid=
#dtb=
###U-Boot Overlays###
###Documentation: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#U-Boot_Overlays
###Master Enable
enable_uboot_overlays=1
###Overide capes with eeprom
#uboot_overlay_addr0=<file0>.dtbo
#uboot_overlay_addr1=<file1>.dtbo
#uboot_overlay_addr2=<file2>.dtbo
#uboot_overlay_addr3=<file3>.dtbo
###Additional custom capes
uboot_overlay_addr4=BB-EHRPWM1-P9_14-P9_16.dtbo
uboot_overlay_addr5=BB-RESERVE-DDR-00A0.dtbo
#uboot_overlay_addr6=<file6>.dtbo
#uboot_overlay_addr7=<file7>.dtbo
###Custom Cape
#dtb_overlay=<file8>.dtbo
###Disable auto loading of virtual capes (emmc/video/wireless/adc)
disable_uboot_overlay_emmc=1
#disable_uboot_overlay_video=1
disable_uboot_overlay_audio=1
disable_uboot_overlay_wireless=1
#disable_uboot_overlay_adc=1
###PRUSS OPTIONS
###pru_rproc (4.14.x-ti kernel)
#uboot_overlay_pru=AM335X-PRU-RPROC-4-14-TI-00A0.dtbo
###pru_rproc (4.19.x-ti kernel)
#uboot_overlay_pru=AM335X-PRU-RPROC-4-19-TI-00A0.dtbo
###pru_uio (4.14.x-ti, 4.19.x-ti & mainline/bone kernel)
#uboot_overlay_pru=AM335X-PRU-UIO-00A0.dtbo
###Cape Universal Enable
#enable_uboot_cape_universal=1
###Debug: disable uboot autoload of Cape
#disable_uboot_overlay_addr0=1
#disable_uboot_overlay_addr1=1
#disable_uboot_overlay_addr2=1
#disable_uboot_overlay_addr3=1
###U-Boot fdt tweaks... (60000 = 384KB)
#uboot_fdt_buffer=0x60000
console=ttyS0,115200n8
cmdline=fsck.repair=yes earlycon coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100
#In the event of edid real failures, uncomment this next line:
#cmdline=fsck.repair=yes earlycon coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 video=HDMI-A-1:1024x768@60e
#Use an overlayfs on top of a read-only root filesystem:
#cmdline=fsck.repair=yes earlycon coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 overlayroot=tmpfs
##enable Generic eMMC Flasher:
#cmdline=init=/usr/sbin/init-beagle-flasher
captured output during boot process:
U-Boot SPL 2022.04-gc6f4cf7d (Apr 24 2025 - 03:22:59 +0000)
Trying to boot from MMC2
U-Boot 2022.04-gc6f4cf7d (Apr 24 2025 - 03:22:59 +0000)
CPU : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM: 512 MiB
RTC 32KCLK Source: External.
Core: 150 devices, 14 uclasses, devicetree: separate
WDT: Started wdt@44e35000 with servicing (60s timeout)
Loading Environment from EXT4...
** Unable to use mmc 0:1 for loading the env **
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone Cape EEPROM: no EEPROM at address: 0x54
BeagleBone Cape EEPROM: no EEPROM at address: 0x55
BeagleBone Cape EEPROM: no EEPROM at address: 0x56
BeagleBone Cape EEPROM: no EEPROM at address: 0x57
Net: eth2: ethernet@4a100000, eth3: usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[A335BNLT] ...
board_rev=[00D0] ...
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Couldn't find partition 0:2 0x82000000
Can't set block device
Scanning mmc 0:1...
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
Scanning disk mmc@48060000.blk...
Scanning disk mmc@481d8000.blk...
Found 8 disks
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
Checking for: /uEnv.txt ...
Checking for: /boot/uEnv.txt ...
2111 bytes read in 4 ms (514.6 KiB/s)
debug: [dtb=am335x-boneblack-revd.dtb] ...
Using: dtb=am335x-boneblack-revd.dtb ...
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-6.18.35-bone38 ...
9118208 bytes read in 579 ms (15 MiB/s)
debug: [enable_uboot_overlays=1] ...
debug: [enable_uboot_cape_universal=] ...
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot.dtb] ...
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot.dtb] ...
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot.dtb ...
loading /boot/dtbs/6.18.35-bone38/am335x-boneblack-uboot.dtb ...
96700 bytes read in 13 ms (7.1 MiB/s)
Found 0 extension board(s).
uboot_overlays: [fdt_buffer=0x60000] ...
uboot_overlays: loading /boot/dtbs/6.18.35-bone38/BB-ADC-00A0.dtbo ...
645 bytes read in 6 ms (104.5 KiB/s)
uboot_overlays: loading /boot/dtbs/6.18.35-bone38/BB-EHRPWM1-P9_14-P9_16.dtbo ...
955 bytes read in 5 ms (186.5 KiB/s)
uboot_overlays: uboot loading of [BB-BONE-eMMC1-01-00A0.dtbo] disabled by /boot/uEnv.txt [disable_uboot_overlay_emmc=1]...
uboot_overlays: uboot loading of [BB-HDMI-TDA998x-00A0.dtbo] disabled by /boot/uEnv.txt [disable_uboot_overlay_audio=1]...
uboot_overlays: loading /boot/dtbs/6.18.35-bone38/BB-NHDMI-TDA998x-00A0.dtbo ...
3438 bytes read in 7 ms (479.5 KiB/s)
loading /boot/initrd.img-6.18.35-bone38 ...
19874766 bytes read in 1271 ms (14.9 MiB/s)
debug: [console=ttyS0,115200n8 root=/dev/mmcblk0p3 ro rootfstype=ext4 rootwait fsck.repair=yes earlycon coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100] ...
debug: [bootz 0x82000000 0x88080000:12f43ce 88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0x8b2200 ]
## Flattened Device Tree blob at 88000000
Loading Ramdisk to 8ed0b000, end 8ffff3ce ... OK
Loading Device Tree to 8ec8f000, end 8ed0afff ... OK
Starting kernel ...
[ 0.000000] Linux version 6.18.35-bone38 (voodoo@rpi4b4g-03) (gcc (Debian 14.2.0-19) 14.2.0, GNU ld (GNU Binutils for Debian) 2.44) #1 SMP PREEMPT Wed Jun 10 20:15:51 UTC 2026
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[ 0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[ 0.000000] Malformed early option 'earlycon'
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 48 MiB at 0x9c800000
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000080000000-0x000000009fefffff]
[ 0.000000] HighMem empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009fefffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fefffff]
[ 0.000000] On node 0, zone Normal: 256 pages in unavailable ranges
[ 0.000000] OF: reserved mem: Reserved memory: No reserved-memory node in the DT
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] percpu: Embedded 20 pages/cpu s51916 r8192 d21812 u81920
[ 0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk0p3 ro rootfstype=ext4 rootwait fsck.repair=yes earlycon coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100
[ 0.000000] printk: log buffer data + meta data: 131072 + 409600 = 540672 bytes
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 130816
[ 0.000000] allocated 531456 bytes of page_ext
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.000000] SLUB: HWalign=16, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] ftrace: allocating 60449 entries in 178 pages
[ 0.000000] ftrace: allocated 178 pages with 4 groups
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] RCU Tasks: Setting shift to 0 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=1.
[ 0.000000] RCU Tasks Rude: Setting shift to 0 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=1.
[ 0.000000] RCU Tasks Trace: Setting shift to 0 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=1.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] TI gptimer clocksource: always-on /ocp/interconnect@44c00000/segment@200000/target-module@31000
[ 0.000002] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000024] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000418] TI gptimer clockevent: 24000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@40000
[ 0.002011] Console: colour dummy device 80x25
[ 0.002111] Calibrating delay loop (skipped) preset value.. 995.32 BogoMIPS (lpj=1990656)
[ 0.002132] CPU: Testing write buffer coherency: ok
[ 0.002237] CPU0: Spectre v2: using BPIALL workaround
[ 0.002247] pid_max: default: 32768 minimum: 301
[ 0.007495] LSM: initializing lsm=capability,landlock,yama,apparmor,tomoyo,bpf,ima,evm
[ 0.009960] landlock: Up and running.
[ 0.009967] Yama: becoming mindful.
[ 0.010519] AppArmor: AppArmor initialized
[ 0.010693] TOMOYO Linux initialized
[ 0.011834] LSM support for eBPF active
[ 0.013924] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.013948] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.025282] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.025338] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.027501] Setting up static identity map for 0x80100000 - 0x80100054
[ 0.027837] rcu: Hierarchical SRCU implementation.
[ 0.027846] rcu: Max phase no-delay instances is 1000.
[ 0.029625] EFI services will not be available.
[ 0.030073] smp: Bringing up secondary CPUs ...
[ 0.030115] smp: Brought up 1 node, 1 CPU
[ 0.030127] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[ 0.030139] CPU: All CPU(s) started in SVC mode.
[ 0.030448] Memory: 420600K/523264K available (13312K kernel code, 2131K rwdata, 6856K rodata, 1024K init, 516K bss, 50660K reserved, 49152K cma-reserved, 0K highmem)
[ 0.031893] devtmpfs: initialized
[ 0.056248] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.057354] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.057419] posixtimers hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.057456] futex hash table entries: 256 (16384 bytes on 1 NUMA nodes, total 16 KiB, linear).
[ 0.064791] pinctrl core: initialized pinctrl subsystem
[ 0.066057] DMI not present or invalid.
[ 0.067397] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.077224] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.077942] audit: initializing netlink subsys (disabled)
[ 0.079899] thermal_sys: Registered thermal governor 'fair_share'
[ 0.079912] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.079921] thermal_sys: Registered thermal governor 'step_wise'
[ 0.079927] thermal_sys: Registered thermal governor 'user_space'
[ 0.079933] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.080050] audit: type=2000 audit(0.076:1): state=initialized audit_enabled=0 res=1
[ 0.080115] cpuidle: using governor ladder
[ 0.105713] /ocp/interconnect@44c00000/segment@200000/target-module@b000/i2c@0/tda19988@70: Fixed dependency cycle(s) with /ocp/interconnect@48000000/segment@300000/target-module@e000/lcdc@0
[ 0.106931] /ocp/interconnect@48000000/segment@300000/target-module@e000/lcdc@0: Fixed dependency cycle(s) with /ocp/interconnect@44c00000/segment@200000/target-module@b000/i2c@0/tda19988@70
[ 0.108698] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.127175] raid6: skipped pq benchmark and selected neonx8
[ 0.127198] raid6: using neon recovery algorithm
[ 0.133238] iommu: Default domain type: Translated
[ 0.133259] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.135038] usbcore: registered new interface driver usbfs
[ 0.135141] usbcore: registered new interface driver hub
[ 0.135199] usbcore: registered new device driver usb
[ 0.135601] pps_core: LinuxPPS API ver. 1 registered
[ 0.135611] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.135635] PTP clock support registered
[ 0.142285] NetLabel: Initializing
[ 0.142300] NetLabel: domain hash size = 128
[ 0.142308] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.142444] NetLabel: unlabeled traffic allowed by default
[ 0.144539] clocksource: Switched to clocksource dmtimer
[ 0.158254] VFS: Disk quotas dquot_6.6.0
[ 0.158570] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.160312] netfs: FS-Cache loaded
[ 0.161434] AppArmor: AppArmor Filesystem Enabled
[ 0.194753] NET: Registered PF_INET protocol family
[ 0.199493] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.201289] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.201504] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.202218] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.202314] TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.202413] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.202794] MPTCP token hash table entries: 512 (order: 1, 8192 bytes, linear)
[ 0.203087] UDP hash table entries: 256 (order: 2, 14336 bytes, linear)
[ 0.203142] UDP-Lite hash table entries: 256 (order: 2, 14336 bytes, linear)
[ 0.207819] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.208928] RPC: Registered named UNIX socket transport module.
[ 0.208945] RPC: Registered udp transport module.
[ 0.208951] RPC: Registered tcp transport module.
[ 0.208956] RPC: Registered tcp-with-tls transport module.
[ 0.208962] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.208979] NET: Registered PF_XDP protocol family
[ 0.209976] Trying to unpack rootfs image as initramfs...
[ 3.748331] Initialise system trusted keyrings
[ 3.751749] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 3.781007] NFS: Registering the id_resolver key type
[ 3.781092] Key type id_resolver registered
[ 3.781100] Key type id_legacy registered
[ 3.781300] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 3.781326] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 3.783695] fuse: init (API version 7.45)
[ 3.788145] SGI XFS with ACLs, security attributes, realtime, scrub, repair, quota, no debug enabled
[ 3.812914] cryptd: max_cpu_qlen set to 1000
[ 4.087621] Freeing initrd memory: 19412K
[ 4.126014] NET: Registered PF_ALG protocol family
[ 4.126061] xor: measuring software checksum speed
[ 4.128665] arm4regs : 1263 MB/sec
[ 4.132163] 8regs : 941 MB/sec
[ 4.135657] 32regs : 941 MB/sec
[ 4.137452] neon : 1836 MB/sec
[ 4.137459] xor: using function: neon (1836 MB/sec)
[ 4.137477] Key type asymmetric registered
[ 4.137487] Asymmetric key parser 'x509' registered
[ 4.137494] Asymmetric key parser 'pkcs8' registered
[ 4.137886] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 4.138403] io scheduler mq-deadline registered
[ 4.140303] target-module@4b000000:target-module@140000:pmu@0:fck: device ID is greater than 24
[ 4.142103] ledtrig-cpu: registered to indicate activity on CPUs
[ 4.146197] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 4.165277] loop: module loaded
[ 4.171961] usbcore: registered new interface driver smsc95xx
[ 4.172249] usbcore: registered new device driver onboard-usb-dev
[ 4.173040] i2c_dev: i2c /dev entries driver
[ 4.174381] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[ 4.174397] softdog: soft_reboot_cmd=<not set> soft_active_on_boot=0
[ 4.174409] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[ 4.174673] device-mapper: uevent: version 1.0.3
[ 4.175219] device-mapper: ioctl: 4.50.0-ioctl (2025-04-28) initialised: dm-devel@lists.linux.dev
[ 4.176479] cpuidle: enable-method property 'ti,am3352' found operations
[ 4.176952] sdhci: Secure Digital Host Controller Interface driver
[ 4.176962] sdhci: Copyright(c) Pierre Ossman
[ 4.177118] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.178088] hid: raw HID events driver (C) Jiri Kosina
[ 4.178634] usbcore: registered new interface driver usbhid
[ 4.178645] usbhid: USB HID core driver
[ 4.180375] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 (8000000f) counters available
[ 4.182261] NET: Registered PF_INET6 protocol family
[ 4.185350] Segment Routing with IPv6
[ 4.185366] RPL Segment Routing with IPv6
[ 4.185442] In-situ OAM (IOAM) with IPv6
[ 4.185576] mip6: Mobile IPv6
[ 4.185598] NET: Registered PF_PACKET protocol family
[ 4.185978] Key type dns_resolver registered
[ 4.185993] mpls_gso: MPLS GSO support
[ 4.186385] ThumbEE CPU extension supported.
[ 4.186406] Registering SWP/SWPB emulation handler
[ 4.186416] omap_voltage_late_init: Voltage driver support not added
[ 4.186754] PM: Cannot get wkup_m3_ipc handle
[ 4.202123] registered taskstats version 1
[ 4.202683] Loading compiled-in X.509 certificates
[ 4.224651] page_owner is disabled
[ 4.225945] Key type .fscrypt registered
[ 4.225961] Key type fscrypt-provisioning registered
[ 4.229733] Btrfs loaded, zoned=yes, fsverity=yes
[ 4.229953] Key type encrypted registered
[ 4.229965] AppArmor: AppArmor sha256 policy hashing enabled
[ 4.230019] ima: No TPM chip found, activating TPM-bypass!
[ 4.230040] ima: Allocated hash algorithm: sha256
[ 4.230130] ima: No architecture policies found
[ 4.230306] evm: Initialising EVM extended attributes:
[ 4.230315] evm: security.selinux
[ 4.230322] evm: security.SMACK64 (disabled)
[ 4.230327] evm: security.SMACK64EXEC (disabled)
[ 4.230332] evm: security.SMACK64TRANSMUTE (disabled)
[ 4.230338] evm: security.SMACK64MMAP (disabled)
[ 4.230343] evm: security.apparmor
[ 4.230348] evm: security.ima
[ 4.230353] evm: security.capability
[ 4.230358] evm: HMAC attrs: 0x1
[ 4.253387] /ocp/interconnect@44c00000/segment@200000/target-module@b000/i2c@0/tda19988@70: Fixed dependency cycle(s) with /ocp/interconnect@48000000/segment@300000/target-module@e000/lcdc@0
[ 4.257792] remoteproc remoteproc0: wkup_m3 is available
[ 4.261681] /ocp/interconnect@44c00000/segment@200000/target-module@b000/i2c@0/tda19988@70: Fixed dependency cycle(s) with /ocp/interconnect@48000000/segment@300000/target-module@e000/lcdc@0
[ 4.273924] /ocp/interconnect@44c00000/segment@200000/target-module@b000/i2c@0/tda19988@70: Fixed dependency cycle(s) with /ocp/interconnect@48000000/segment@300000/target-module@e000/lcdc@0
[ 4.274729] /ocp/interconnect@44c00000/segment@200000/target-module@b000/i2c@0/tda19988@70: Fixed dependency cycle(s) with /ocp/interconnect@48000000/segment@300000/target-module@e000/lcdc@0
[ 4.280778] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[ 4.289831] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 4.293938] omap_rtc 44e3e000.rtc: registered as rtc0
[ 4.293997] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:00:00 UTC (946684800)
[ 4.296977] /ocp/interconnect@48000000/segment@300000/target-module@e000/lcdc@0: Fixed dependency cycle(s) with /ocp/interconnect@44c00000/segment@200000/target-module@b000/i2c@0/tda19988@70
[ 4.317491] OMAP GPIO hardware version 0.1
[ 4.324380] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 4.331743] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 4.345024] 48000000.interconnect:segment@200000:target-module@0:mpu@0:fck: device ID is greater than 24
[ 4.346583] /ocp/interconnect@48000000/segment@300000/target-module@e000/lcdc@0: Fixed dependency cycle(s) with /ocp/interconnect@44c00000/segment@200000/target-module@b000/i2c@0/tda19988@70
[ 4.352493] /ocp/interconnect@48000000/segment@300000/target-module@e000/lcdc@0: Fixed dependency cycle(s) with /ocp/interconnect@44c00000/segment@200000/target-module@b000/i2c@0/tda19988@70
[ 4.353140] /ocp/interconnect@44c00000/segment@200000/target-module@b000/i2c@0/tda19988@70: Fixed dependency cycle(s) with /ocp/interconnect@48000000/segment@300000/target-module@e000/lcdc@0
[ 4.353293] /ocp/interconnect@48000000/segment@300000/target-module@e000/lcdc@0: Fixed dependency cycle(s) with /ocp/interconnect@44c00000/segment@200000/target-module@b000/i2c@0/tda19988@70
[ 4.358011] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 4.360066] random: crng init done
[ 4.403416] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 4.481887] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 4.482598] cpsw-switch 4a100000.switch: initialized cpsw ale version 1.4
[ 4.482617] cpsw-switch 4a100000.switch: ALE Table size 1024, Policers 0
[ 4.482743] cpsw-switch 4a100000.switch: cpts: overflow check period 1250 (jiffies)
[ 4.482760] cpsw-switch 4a100000.switch: CPTS: ref_clk_freq:250000000 calc_mult:2147483648 calc_shift:29 error:0 nsec/sec
[ 4.482876] cpsw-switch 4a100000.switch: Detected MACID = 48:84:9d:77:c2:6f
[ 4.485134] cpsw-switch 4a100000.switch: initialized (regs 0x4a100000, pool size 256) hw_ver:0019010C 1.12 (0)
[ 4.499835] debugfs: '49000000.dma' already exists in 'dmaengine'
[ 4.499874] edma 49000000.dma: TI EDMA DMA engine driver
[ 4.505972] am335x-phy-driver 47401300.usb-phy: dummy supplies not allowed for exclusive requests (id=vbus)
[ 4.514007] am335x-phy-driver 47401b00.usb-phy: dummy supplies not allowed for exclusive requests (id=vbus)
[ 4.517747] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 4.517795] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 4.518153] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
[ 4.518171] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.518182] usb usb1: Product: MUSB HDRC host driver
[ 4.518191] usb usb1: Manufacturer: Linux 6.18.35-bone38 musb-hcd
[ 4.518199] usb usb1: SerialNumber: musb-hdrc.1
[ 4.519149] hub 1-0:1.0: USB hub found
[ 4.519221] hub 1-0:1.0: 1 port detected
[ 4.543051] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 4.543554] omap-sham 53100000.sham: will run requests pump with realtime priority
[ 4.545427] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 4.545863] omap-aes 53500000.aes: will run requests pump with realtime priority
[ 4.548444] ti-sysc 44e31000.target-module: Failed to create device link (0x180) with supplier ocp for /ocp/interconnect@44c00000/segment@200000/target-module@31000/timer@0
[ 4.548499] ti-sysc 48040000.target-module: Failed to create device link (0x180) with supplier ocp for /ocp/interconnect@48000000/segment@0/target-module@40000/timer@0
[ 4.560428] PM: Cannot get wkup_m3_ipc handle
[ 4.572397] printk: legacy console [ttyS0] disabled
[ 4.575691] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 41, base_baud = 3000000) is a 8250
[ 4.575796] printk: legacy console [ttyS0] enabled
[ 6.271476] tda998x 0-0070: Error -121 writing to cec:0xff
[ 6.277170] tda998x 0-0070: set_page 000a err -121
[ 6.335447] tda998x 0-0070: set_page 000a err -121
[ 6.395458] tda998x 0-0070: set_page 0001 err -121
[ 6.400376] tda998x 0-0070: set_page 0001 err -121
[ 6.405282] tda998x 0-0070: set_page 0200 err -121
[ 6.410184] tda998x 0-0070: set_page 0201 err -121
[ 6.415183] tda998x 0-0070: set_page 0202 err -121
[ 6.420137] tda998x 0-0070: set_page 0203 err -121
[ 6.425109] tda998x 0-0070: set_page 0204 err -121
[ 6.430013] tda998x 0-0070: set_page 0205 err -121
[ 6.434915] tda998x 0-0070: set_page 020e err -121
[ 6.439821] tda998x 0-0070: set_page 0211 err -121
[ 6.444721] tda998x 0-0070: set_page 0207 err -121
[ 6.449625] tda998x 0-0070: set_page 0208 err -121
[ 6.454526] tda998x 0-0070: set_page 0209 err -121
[ 6.459427] tda998x 0-0070: set_page 020a err -121
[ 6.464326] tda998x 0-0070: set_page 0206 err -121
[ 6.469226] tda998x 0-0070: set_page 0027 err -121
[ 6.474126] tda998x 0-0070: set_page 0000 err -121
[ 6.478967] tda998x 0-0070: failed to read version: -121
[ 6.484352] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[ 6.491100] tda998x 0-0070: probe with driver tda998x failed with error -121
[ 6.500275] tps65217-pmic: Failed to locate of_node [id: -1]
[ 6.506848] tps65217-bl: Failed to locate of_node [id: -1]
[ 6.515860] platform tps65217-charger: DMA mask not set
[ 6.525925] platform tps65217-pwrbutton: DMA mask not set
[ 6.534805] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 6.541218] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 6.549853] remoteproc remoteproc0: powering up wkup_m3
[ 6.556531] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[ 6.574800] PM: Cannot get wkup_m3_ipc handle
[ 6.579467] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[ 6.587680] sdhci-omap 48060000.mmc: Got CD GPIO
[ 6.593879] input: tps65217_pwrbutton as /devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-module/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[ 6.612291] sdhci-omap 48060000.mmc: supply pbias not found, using dummy regulator
[ 6.620245] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 6.620270] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[ 6.634567] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
[ 6.643643] PM: Cannot get wkup_m3_ipc handle
[ 6.648978] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[ 6.660841] PM: bootloader does not support rtc-only!
[ 6.667564] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 6.686099] usb 1-1: Product: USB 2.0 Hub
[ 6.690365] clk: Disabling unused clocks
[ 6.700556] PM: genpd: Disabling unused power domains
[ 6.706039] hub 1-1:1.0: USB hub found
[ 6.715780] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA
[ 6.723850] hub 1-1:1.0: 4 ports detected
[ 6.739484] Freeing unused kernel image (initmem) memory: 1024K
[ 6.747078] Run /init as init process
Loading, please wait...
Starting systemd-udevd version 257.13-1~deb13u1
[ 6.909322] mmc0: new high speed SDHC card at address aaaa
[ 6.924968] mmcblk0: mmc0:aaaa SB16G 14.8 GiB
[ 6.952645] mmcblk0: p1 p2 p3
[ 7.135527] usb 1-1.2: new low-speed USB device number 3 using musb-hdrc
[ 7.362091] usb 1-1.2: New USB device found, idVendor=413c, idProduct=2113, bcdDevice=33.08
[ 7.387624] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 7.411566] usb 1-1.2: Product: Dell KB216 Wired Keyboard
[ 7.448927] input: Dell KB216 Wired Keyboard as /devices/platform/ocp/47400000.target-module/47401c00.usb/musb-hdrc.1/usb1/1-1/1-1.2/1-1.2:1.0/0003:413C:2113.0001/input/input1
[ 7.588621] hid-generic 0003:413C:2113.0001: input,hidraw0: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-musb-hdrc.1-1.2/input0
[ 7.625032] input: Dell KB216 Wired Keyboard System Control as /devices/platform/ocp/47400000.target-module/47401c00.usb/musb-hdrc.1/usb1/1-1/1-1.2/1-1.2:1.1/0003:413C:2113.0002/input/input2
[ 7.724009] input: Dell KB216 Wired Keyboard Consumer Control as /devices/platform/ocp/47400000.target-module/47401c00.usb/musb-hdrc.1/usb1/1-1/1-1.2/1-1.2:1.1/0003:413C:2113.0002/input/input3
[ 7.780468] hid-generic 0003:413C:2113.0002: input,hiddev0,hidraw1: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-musb-hdrc.1-1.2/input1
[ 8.007540] usb 1-1.3: new low-speed USB device number 4 using musb-hdrc
[ 8.243960] usb 1-1.3: New USB device found, idVendor=0461, idProduct=4d51, bcdDevice= 7.17
[ 8.271519] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 8.292964] usb 1-1.3: Product: DELL Laser Mouse
[ 8.316760] input: DELL Laser Mouse as /devices/platform/ocp/47400000.target-module/47401c00.usb/musb-hdrc.1/usb1/1-1/1-1.3/1-1.3:1.0/0003:0461:4D51.0003/input/input4
[ 8.363945] hid-generic 0003:0461:4D51.0003: input,hidraw2: USB HID v1.11 Mouse [DELL Laser Mouse] on usb-musb-hdrc.1-1.3/input0
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... Booting Linux on physical CPU 0x0
Zone ranges:
HighMem empty
pcpu-alloc: s51916 r8192 d21812 u81920 alloc=20*4096
pcpu-alloc: [0] 0
8regs : 941 MB/sec
32regs : 941 MB/sec
neon : 1836 MB/sec
loop: module loaded
done.
Begin: Mounting root file system ... usbhid: USB HID core driver
Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems
done.
Begin: Will now check root file system ... fsck from util-linux 2.41
mip6: Mobile IPv6
16.213519] EXT4-fs (mmcblk0p3): mounted filesystem 85ee7953-2396-4643-b497-414b13b1a0c0 ro with ordered data mode. Quota mode: none.
;21;39mevm: security.SMACK64EXEC (disabled)
evm: security.ima
[/sbin/fsck.ext4 (1) -- /dev/mmcblk0p3] fsck.ext4 -y -C0 /dev/mmcblk0p3
e2fsck 1.47.2 (1-Jan-2025)
rootfs: clean, 211629/934720 files, 890783/3748219 blocks
done.
done.
Begin: Running /scripts/local-bottom ... done.
Begin: Running /scripts/init-bottom ... /ocp/interconnect@48000000/segment@300000/target-module@e000/lcdc@0: Fixed dependency cycle(s) with /ocp/interconnect@44c00000/segment@200000/target-module@b000/i2c@0/tda19988@70
done.
usb 1-1: New USB de[ 16.968625] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
with arguments:
/init
with environment:
HOME=/
TERM=linux
mmcblk0: p1 p2 p3
[ 17.598965] systemd[1]: System time advanced to timestamp on /var/lib/systemd/timesync/clock: Mon 2026-06-15 16:46:09 MDT
[ 17.860924] systemd[1]: systemd 257.13-1~deb13u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE)
[ 17.896786] systemd[1]: Detected architecture arm.
systemd[1]: systemd 257.13-1~deb13u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCH[ 17.934138] systemd[1]: Hostname set to <BeagleBone>.
IVE)
Welcome to Debian GNU/Linux 13 (trixie)!
[ 19.015708] zram: Added device: zram0
[ 20.472685] systemd[1]: Queued start job for default target graphical.target.
[ 20.568652] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[ OK ] Created slice system-getty.slice - Slice /system/getty.
systemd[1]: Created slice [ 20.583804] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[ OK ] Created slice system-modprobe.slice[ 20.603315] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
20.622142] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
1;39msystemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[ OK ] Created slice[ 20.642321] systemd[1]: Created slice system-systemd\x2dzram\x2dsetup.slice - Slice /system/systemd-zram-setup.
system-serial\x2dgetslice - Slice /system/seria[ 20.661760] systemd[1]: Created slice user.slice - User and Session Slice.
l-getty.
[ OK ] Created slice system-sy[ 20.670860] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
stemd\x2dfsslice - Slice /system/systemd-fsck.
20.688687] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
39msystemd[1]: Created slice system-systemd\x2dfsck.slice - Slic[ 20.704833] systemd[1]: Expecting device dev-mmcblk0p1.device - /dev/mmcblk0p1...
[ OK ] Created slice systemd[1]: Expecting device dev-mmcblk0p2.device - /dev/mmcblk0p2...
[0;1;39msystem-systemd\x2dzr- Slice /system/systemd-zram-[ 20.730994] systemd[1]: Expecting device dev-ttyS0.device - /dev/ttyS0...
setup.
systemd[1]: Created slice system-systemd\x2d[ 20.743556] systemd[1]: Expecting device dev-zram0.device - /dev/zram0...
[ 20.756193] systemd[1]: Reached target remote-fs.target - Remote File Systems.
0;32m OK ] Created slice user.slice - User an[ 20.769089] systemd[1]: Reached target slices.target - Slice Units.
d Session Slice.
systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wa[ 20.794560] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption.
ll Directory Watch.
[ OK ] Started sy[ 20.807890] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
stemd-ask-password-wall.d Requests to Wall Directory Watc[ 20.822773] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
h.
[ OK ] Set up automount proc-sys-fs-[ 20.837176] systemd[1]: Listening on systemd-journald.socket - Journal Sockets.
binfmormats File System Automount Point.
sys[ 20.850000] systemd[1]: Listening on systemd-networkd.socket - Network Service Netlink Socket.
temd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Ar[ 20.863043] systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements skipped, unmet condition check ConditionSecurity=measured-uki
bitrary Executable File Formats File System Automount Point.[ 20.879974] systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy skipped, unmet condition check ConditionSecurity=measured-uki
systemd[1]: Expecting device dev-mmcblk0p1.device - [ 20.898383] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
/dev/mmcblk0p1...
Expecting device dev-mm[ 20.913820] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
systemd[1]: [ 20.926450] systemd[1]: dev-hugepages.mount - Huge Pages File System skipped, unmet condition check ConditionPathExists=/sys/kernel/mm/hugepages
systemd[1]: Expecting device dev-tty[ 20.957921] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
systemd[1]: Reached target remote-fs.target - Remote[ 20.990800] systemd[1]: Mounting run-lock.mount - Legacy Locks Directory /run/lock...
File Systems.
[ OK ] Reached target remote-fs.target - Remote File Systems.
[ OK ] Reached target slices.target - Slice Units.
[ OK ] Listening on systemd-creds.socket - Credential Encryption/Decryption.
[ OK ] Listening on systemd-initctl.socke- initctl Compatibility Named Pipe.
systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).[ 21.065394] systemd[1]: Mounting sys-kernel-debug.mount - /sys/kernel/debug...
[ OK ] Listening on systemd-journald-dev-socket - Journal Socket (/dev/log).
[ OK ] Listening on systemd-journald.socket - Journal Sockets.
[ OK ] Listening on systemd-networkd.socket - Network Service Netlink Socket.
[ OK ] Listening on systemd-udevd-control.socket - udev Control Socket.
[[ 21.162044] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
OK ] Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[ 21.273761] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
Starting kmod-static-nodes.serviceeate List of Static Device Nodes...
[ 21.407074] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[ 21.536793] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[ 21.657799] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
Starting modprobe@efi_pstore.servi - Load Kernel Module efi_pstore...
[ 21.816933] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[ 21.861282] systemd[1]: systemd-fsck-root.service - File System Check on Root Device skipped, unmet condition check ConditionPathExists=!/run/initramfs/fsck-root
[ 21.960326] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67
[ 22.134756] systemd[1]: Starting systemd-journald.service - Journal Service...
[ 22.217982] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[ 22.278465] systemd[1]: Starting systemd-network-generator.service - Generate Network Units from Kernel Command Line...
Starting systemd-network-generatork Uni[ 22.328837] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement skipped, unmet condition check ConditionSecurity=measured-uki
[ 22.449497] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
Starting systemd-remount-fs.servicunt R[ 22.509196] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
[ 22.713844] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials...
Starting systemd-udev-load-credentLoad udev Rules from Credentials...
[ 22.918228] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[ 22.990759] systemd-journald[262]: Collecting audit messages is disabled.
[ 23.268778] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[ 23.312318] EXT4-fs (mmcblk0p3): re-mounted 85ee7953-2396-4643-b497-414b13b1a0c0 r/w.
[ OK ] Mounted dev-mqueue.mount - POSIX Message Queue File System.
[ 23.402269] systemd[1]: Mounted run-lock.mount - Legacy Locks Directory /run/lock.
[ OK ] Mounted run-lock.mount - Legacy Locks Directory /run/lock.
[ 23.497393] systemd[1]: Mounted sys-kernel-debug.mount - /sys/kernel/debug.
[ OK ] Mounted sys-kernel-debug.mount - /sys/kernel/debug.
systemd[1]: Mounted sys-kernel[ 23.547900] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[ OK ] Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[ 23.606645] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[ OK ] Finished kmod-static-nodes.serviceCreate List of Static Device Nodes.
systemd[1]: Finished kmod-static-nodes.service - Create List of Static De[ 23.663238] systemd[1]: modprobe@configfs.service: Deactivated successfully.
vice Nodes.
systemd[1]: modprobe@configfs.service: Deactivated suc[ 23.716515] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
cessfully.
[ OK ] Finished modprobe@configfs.service - Load Kernel Module configfs.
systemd[1]: Fini[ 23.773867] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 23.808135] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[ OK ] Finished modprob[ 23.842102] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[ 23.895933] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[ OK ] Finished 23.936583] systemd[1]: modprobe@fuse.service: Deactivated successfully.
0;1;39mmodprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[ 23.976858] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[ OK ] Finished modprobe@fuse.service - Load Kernel Module fuse.
[ 24.016108] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[ OK ] Finished systemd-modules-load.service - Load Kernel Modules.
systemd[1]: Finished [ 24.054240] systemd[1]: Started systemd-journald.service - Journal Service.
[ OK ] Started systemd-journald.service - Journal Service.
[ OK ] Finished systemd-network-generatorork Units from Kernel Command Line.
[ OK ] Finished systemd-remount-fs.servicmount Root and Kernel File Systems.
[ OK ] Finished systemd-udev-load-credent- Load udev Rules from Credentials.
Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
Mounting sys-kernel-config.mount - Kernel Configuration File System...
Starting systemd-journal-flush.sersh Journal to Persistent Storage...
Starting systemd-random-seed.service - Load/Save OS Random Seed...
Starting systemd-sysctl.service - Apply Kernel Variables...
Starting systemd-tmpfiles-setup-de Device Nodes in /dev gracefully...
[ OK ] Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[ OK ] Mounted sys-kernel-config.mount - Kernel Configuration File System.
[ 25.654506] systemd-journald[262]: Received client request to flush runtime journal.
[ OK ] Finished systemd-random-seed.service - Load/Save OS Random Seed.
[ OK ] Finished systemd-sysctl.service - Apply Kernel Variables.
[ OK ] Finished systemd-tmpfiles-setup-deic Device Nodes in /dev gracefully.
Starting systemd-resolved.service - Network Name Resolution...
Starting systemd-timesyncd.service - Network Time Synchronization...
Starting systemd-tmpfiles-setup-deeate Static Device Nodes in /dev...
[ OK ] Finished systemd-journal-flush.serlush Journal to Persistent Storage.
[ OK ] Finished systemd-tmpfiles-setup-deCreate Static Device Nodes in /dev.
[ OK ] Reached target local-fs-pre.targetPreparation for Local File Systems.
Starting systemd-udevd.service - Rager for Device Events and Files...
[ OK ] Finished systemd-udev-trigger.service - Coldplug All udev Devices.
Starting ifupdown-pre.service - Hesynchronize boot up for ifupdown...
[ OK ] Finished ifupdown-pre.service - Heo synchronize boot up for ifupdown.
[ OK ] Started systemd-timesyncd.service - Network Time Synchronization.
[ OK ] Reached target time-set.target - System Time Set.
[ OK ] Started systemd-udevd.service - Ruanager for Device Events and Files.
Starting plymouth-start.service - Show Plymouth Boot Screen...
[ OK ] Started systemd-resolved.service - Network Name Resolution.
[ OK ] Reached target nss-lookup.target - Host and Network Name Lookups.
[ OK ] Started plymouth-start.service - Show Plymouth Boot Screen.
[ OK ] Started systemd-ask-password-plymoquests to Plymouth Directory Watch.
[ OK ] Reached target paths.target - Path Units.
[ OK ] Found device dev-zram0.device - /dev/zram0.
Starting systemd-zram-setup@zram0.vice - Create swap on /dev/zram0...
[ 30.838596] zram0: detected capacity change from 0 to 492544
[ OK ] Finished systemd-zram-setup@zram0.service - Create swap on /dev/zram0.
Activating swap dev-zram0.swap - Compressed Swap on /dev/zram0...
[ 31.417483] Adding 246268k swap on /dev/zram0. Priority:100 extents:1 across:246268k SSDsc
[ OK ] Activated swap dev-zram0.swap - Compressed Swap on /dev/zram0.
[ OK ] Found device dev-ttyS0.device - /dev/ttyS0.
[ OK ] Found device dev-mmcblk0p2.device - /dev/mmcblk0p2.
[ OK ] Found device dev-mmcblk0p1.device - /dev/mmcblk0p1.
Activating swap dev-mmcblk0p2.swap - /dev/mmcblk0p2...
Starting systemd-fsck@dev-mmcblk0pe System Check on /dev/mmcblk0p1...
[ 34.918126] Adding 524284k swap on /dev/mmcblk0p2. Priority:-2 extents:1 across:524284k SS
[ OK ] Activated swap dev-mmcblk0p2.swap - /dev/mmcblk0p2.
[ OK ] Reached target swap.target - Swaps.
[ OK ] Finished systemd-fsck@dev-mmcblk0pile System Check on /dev/mmcblk0p1.
Mounting boot-firmware.mount - /boot/firmware...
[ OK ] Mounted boot-firmware.mount - /boot/firmware.
[ OK ] Reached target local-fs.target - Local File Systems.
[ OK ] Listening on systemd-sysext.socket System Extension Image Management.
Starting console-setup.service - Set console font and keymap...
Starting plymouth-read-write.serviymouth To Write Out Runtime Data...
Starting systemd-binfmt.service - Set Up Additional Binary Formats...
Starting systemd-tmpfiles-setup.seate System Files and Directories...
Starting ufw.service - Uncomplicated firewall...
[ OK ] Finished console-setup.service - Set console font and keymap.
[ OK ] Finished plymouth-read-write.serviPlymouth To Write Out Runtime Data.
[ OK ] Finished ufw.service - Uncomplicated firewall.
[ OK ] Reached target network-pre.target - Preparation for Network.
Mounting proc-sys-fs-binfmt_misc.mcutable File Formats File System...
Starting networking.service - Raise network interfaces...
Starting systemd-networkd.service - Network Configuration...
[ OK ] Finished systemd-tmpfiles-setup.sereate System Files and Directories.
[ OK ] Mounted proc-sys-fs-binfmt_misc.moxecutable File Formats File System.
[ OK ] Finished systemd-binfmt.service - Set Up Additional Binary Formats.
[ OK ] Reached target sysinit.target - System Initialization.
[ OK ] Started apt-daily.timer - Daily apt download activities.
[ OK ] Started apt-daily-upgrade.timer - y apt upgrade and clean activities.
[ OK ] Started dpkg-db-backup.timer - Daily dpkg database backup timer.
[ OK ] Started e2scrub_all.timer - PeriodMetadata Check for All Filesystems.
[ OK ] Started fstrim.timer - Discard unused filesystem blocks once a week.
[ OK ] Started logrotate.timer - Daily rotation of log files.
[ OK ] Started man-db.timer - Daily man-db regeneration.
[ OK ] Started systemd-tmpfiles-clean.timy Cleanup of Temporary Directories.
[ OK ] Reached target timers.target - Timer Units.
[ OK ] Listening on dbus.socket - D-Bus System Message Bus Socket.
[ OK ] Listening on sshd-unix-local.socketemd-ssh-generator, AF_UNIX Local).
[ OK ] Listening on systemd-hostnamed.socket - Hostname Service Socket.
[ OK ] Reached target sockets.target - Socket Units.
[ OK ] Reached target basic.target - Basic System.
Starting bb-symlinks.service - BeagleBoard Generate Symlinks...
[ OK ] Started cron.service - Regular background program processing daemon.
Starting dbus.service - D-Bus System Message Bus...
Starting e2scrub_reap.service - Rene ext4 Metadata Check Snapshots...
Starting systemd-logind.service - User Login Management...
Starting udisks2.service - Disk Manager...
[ OK ] Finished bb-symlinks.service - BeagleBoard Generate Symlinks.
[ OK ] Started dbus.service - D-Bus System Message Bus.
[ OK ] Finished networking.service - Raise network interfaces.
[ OK ] Finished e2scrub_reap.service - Reline ext4 Metadata Check Snapshots.
Starting polkit.service - Authorization Manager...
[ OK ] Started systemd-logind.service - User Login Management.
[ 42.695513] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 42.731103] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'[ 42.760621] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ OK ] Started systemd-networkd.service - Network Configuration.
[ 43.124236] cpsw-switch 4a100000.switch: starting ndev. mode: dual_mac
[ OK ] Reached target network.target - Network.
Starting ssh.service - OpenBSD Secure Shell server...
Starting systemd-networkd-persistetent Storage in systemd-networkd...
[ 43.318932] SMSC LAN8710/LAN8720 4a101000.mdio:00: attached PHY driver (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL)
Starting systemd-user-sessions.service - Permit User Sessions...
[ OK ] Started unattended-upgrades.service - Unattended Upgrades Shutdown.
[ OK ] Finished systemd-user-sessions.service - Permit User Sessions.
[ OK ] Finished systemd-networkd-persisteistent Storage in systemd-networkd.
Starting plymouth-quit-wait.servicd until boot process finishes up...
Starting plymouth-quit.service - Terminate Plymouth Boot Screen...
[ 45.483585] cpsw-switch 4a100000.switch eth0: Link is Up - 100Mbps/Full - flow control off
[ OK ] Started polkit.service - Authorization Manager.
[ 47.271853] at24 2-0054: supply vcc not found, using dummy regulator
[ 47.664289] at24 2-0055: supply vcc not found, using dummy regulator
[ 48.064928] at24 2-0056: supply vcc not found, using dummy regulator
[ 48.248264] at24 2-0057: supply vcc not found, using dummy regulator
[ 48.568176] at24 0-0050: 4096 byte 24c32 EEPROM, writable, 1 bytes/write
Sorry I’m really blind in this area, and I don’t understand what is going between /boot/uEnv.txt, u-boot, and overlays to cause this NHDMI-TDA overlay to try to load and fail on this beaglebone in particular but not on the other.
