Technical Reference Manual for bbai64
Hi Community,
I’m trying to track down the appropriate TI TRM for bbai64. I’m currently using these as reference:
(SPRUIM2H) AM64x /AM243x Processors Silicon Revision 2.0
(SPRUIL1C) J721E DRA829/TDA4VM Processors Silicon Revision 1.1
But the j721e doc is missing PRU ICSGG chapter/sections and I’ve confused what exactly the chip is on the bbai64.
I’m looking for the full pinmux options, ball number, and registers so I can adapt the device-tree and pinmux for my own applications.
Over the years I’ve been using BBB with PRUs for my academic research: GitHub - jonreal/openWearable
I have mostly successfully ported my project (openWearable) to bbai64 on ICSGG0, but want more control over pinmuxing. Here is the bbai64 branch, which is a work in progress: GitHub - jonreal/openWearable at am64x
I have found a table of pinmux for bbai64 on this forum, but I’m interested in how this table was put together, eg which TI TRMs include the information.
Here’s my current overlay setup for reference: https://github.com/kevinacahalan/BeagleBoneAI64_Heterogeneous_App_Example/blob/master/custom_overlays/our-custom-bbai64-overlay.dtso
This guy has some PRU examples
Thanks for the great collection of resources.
I’m still confused why the TRM doesn’t have a PRU section. To be clear, I can use the PRUs on my board without issue but wanted the technical reference as a guide.
I figure that table was put together with a mix of looking at the TDA4VM datasheet SoC pad tables, and matching those pad numbers with their corresponding BB pins as seen here: https://docs.beagleboard.org/boards/beaglebone/ai-64/03-design-and-specifications.html#p8-cape-header.
So for example, you can see that SoC pad AH21 maps to BB pin P8_03. From looking at the TDA4VM datasheet page 46 table 5-1, you can see that AH21 needs to be in mux mode 6 to be MCAN6_TX.
I have this walkthrough of custom pinmuxing that you may find helpful: https://github.com/kevinacahalan/BeagleBoneAI64_Heterogeneous_App_Example?tab=readme-ov-file#walkthrough-of-process-to-figure-out-muxing
The PRUs are not officially supported for whatever dumb reason. Oddly there are some TI examples for them. https://git.ti.com/cgit/pru-software-support-package/pru-software-support-package/tree/examples/j721e
In the datasheet you see this, which is a lie…
This was my main confusion. I see now where the SoC pads are in the data sheet including PRU capable pads. Thanks for your help – it’s exactly the answers I was looking for.
