TFTP boot and NFS?
I am having some serious problems getting TFTP boot to work. Apparently no problems accessing a zImage or .dtb from other machines on the network. The bone on the other hand plain nuts. Need to investigate further.
1 question. Saveenv appears to be disabled in the current u-boot build. Any reason for this?
How then to clear everything without rebuilding and installing u-boot?
I need to be able to drive u-boot from the command line to see if I can get tftp and bootz to work.
TAIA.
P.S. We’ll leave the NFS side of things for later. That too appears whacked on the B3.
reason for this?
It's disabled as it was causing boot issues on the beaglebone white..
TAIA.
on the B3.
BTW, the default u-boot has a few things already setup for nfs.
To enable it, via (/boot/uEnv.txt) set client_ip to your whish'ed ip address..
client_ip=192.168.(something..)
Next, these are set by default:
For starters, we’d need to see your uEnv.txt file. After that, while it is possible to troubleshoot an issue like this without a serial debug cable( I’ve done it, and it is not any fun ). You’d have to be very meticulous, and know exactly how the process works completely.
Anyway here is a link to a guide I wrote a couple years ago: http://www.embeddedhobbyist.com/2013/06/beaglebone-black-network-boot/
Keep in mind that zImage should now work, so everything pertaining to uImage needs to be changed, or ignored( in the case of mkimage ).
Just a note though . . . You need flash media ( sdcard / eMMC ) anyway, for MLO and uboot.image . . . so I figure what does it hurt to boot the kernel off flash media, and just load the rootfs from NFS ? Anyway, this is what I do now days myself, so have not personally bothered with TFTP boot since I wrote that guide.
Also as a guide . . .
debian@beaglebone:~$ cat /nfs-uEnv.txt
##Rename as: uEnv.txt to boot via nfs
##https://www.kernel.org/doc/Documentation/filesystems/nfs/nfsroot.txt
##SERVER: sudo apt-get install tftpd-hpa
##SERVER: TFTP_DIRECTORY defined in /etc/default/tftpd-hpa
##SERVER: zImage/.dtb need to be located here:
##SERVER: TFTP_DIRECTORY/zImage
##SERVER: TFTP_DIRECTORY/dtbs/
.dtb
##client_ip needs to be set for u-boot to try booting via nfs
client_ip=192.168.1.101
#u-boot defaults: uncomment and override where needed
#server_ip=192.168.1.100
#gw_ip=192.168.1.1
#netmask=255.255.255.0
#hostname=
#device=eth0
#autoconf=off
#root_dir=/home/userid/targetNFS
#nfs_options=,vers=3
#nfsrootfstype=ext4 rootwait fixrtc
One last thing I just remembered . . . ip_addr has to be defined, and correct in order to use TFTP boot. I talked with Robert about this a long time ago, but do not remember if client_ip is tied to ip_addr or not.
Yeap, client_ip is the magic uEnv.txt variable. That's the hint for
the state loop to run thru the nfs function..
Hello William. Thanks.
> For starters, we'd need to see your uEnv.txt file. After that, while it is possible to troubleshoot an issue like this without a serial debug cable( I've done it, and it is not any fun ). You'd > have to be very meticulous, and know exactly how the process works completely.
Serial cable is always in use :slight_smile: Some uEnv and serial spew at end of post. It does not look like it even tries to TFTP zImage+dtb
Yep. Saw that in my travels. Very useful but a little dated.
Just a note though . . . You *need* flash media ( sdcard / eMMC ) anyway, for MLO and uboot.image . . . so I figure what does it hurt to boot the kernel off flash media, and just load
Yes, I certainly understand that. At the moment I'm just trying to make sure I've got 100% control over then environment. And it don't feel that way :slight_smile:
TAIA
----------------------------------------------------uEnv
uname_r=4.1.0-bone9
loadaddr=0x82000000
fdtaddr=0x88000000
rdaddr=0x88080000
initrd_high=0xffffffff
fdt_high=0xffffffff
console=ttyO0,115200n8
ipaddr=192.168.1.111
serverip=192.168.1.115
gateway=192.168.1.254
bootdelay=1
bootfile=boot/zImage
fdtfile=boot/dtbs/4.1.0-bone9/am335x-boneblack.dtb
rootpath=/home/jevans/bone/rootfs
netargs=setenv bootargs console=${console} ${optargs} root=/dev/nfs rootdelay=10 nfsroot=${serverip}:${rootpath},${nfsopts} rw ip=${ipaddr}:${serverip}:${gateway}:${netmask}:${hostname}:eth0:off
netboot=echo ----------BOOTING NFS----------; tftp ${loadaddr} ${bootfile}; tftp ${fdtaddr} ${fdtfile}; run netargs; bootz ${loadaddr} - ${fdtaddr}
uenvcmd=run netboot
--------------------------------serial (seriously snipped with just a few odd bits-------------------------
cpsw
switch to partitions #0, OK
mmc0 is current device
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
785 bytes read in 17 ms (44.9 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-4.1.0-bone9 ...
6878968 bytes read in 394 ms (16.7 MiB/s)
loading /boot/boot/dtbs/4.1.0-bone9/am335x-boneblack.dtb ...
** File not found /boot/boot/dtbs/4.1.0-bone9/am335x-boneblack.dtb **
debug: [console=ttyO0,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait fixrtc] ...
debug: [bootz 0x82000000 - 0x88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0x68f6f8 ]
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
Yeap, client_ip is the magic uEnv.txt variable. That's the hint for the state
Ah!. Now that makes sense of some of the apparent insanity :slight_smile:
I'm guessing that I'm reading stuff that has slipped out of currency ...
TAIA
uname_r=4.1.0-bone9
loadaddr=0x82000000
fdtaddr=0x88000000
rdaddr=0x88080000
^^ not needed, defined by default..
fdt_high=0xffffffff
#use:
client_ip=192.168.1.111
server_ip=192.168.1.115
gateway=192.168.1.1
root_dir=/home/jevans/bone/rootfs
bootdelay=1
uenvcmd=run netboot
# drop these, client_ip defaults to^^^
To sumarize:
#--------------------------------summary, simplified uEnv.txt with uname_r-----
uname_r=4.1.0-bone9
gateway=192.168.1.1
opps ment: gateway=192.168.1.254
But i think you get the idea..
