I am building u-boot-2013.10 using omap3_beagle_config for my Beagleboard xm (without any changes to the configuration). The /include/configs/omap3_beagle.h file says “Configuration settings for the TI OMAP3530 Beagle board” but I am assuming it also works for the Beagleboard xm 3730.
The commands (see below)
usb start
tftp 0x80000000 uImage
don’t work on this setup. I know my host Ubuntu machine is set up correctly since I can get get tftp working on an igepv2 board.
I have read both: that tftp in u-boot does work and doesn’t work on the beagleboard xm.
My question is - does tftp on u-boot work on the beagleboard xm?
If yes, what am I missing?
my uboot log is below
U-Boot 2013.10 (Nov 24 2013 - 21:50:38)
OMAP36XX/37XX-GP ES1.2, CPU-OPP2, L3-200MHz, Max CPU Clock 1 Ghz
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
In: serial
Out: serial
Err: serial
Beagle xM Rev C
No EEPROM on expansion board
Die ID #3eb200229ff8000001469c631502302d
Net: usb_ether
OMAP3 beagleboard.org #
OMAP3 beagleboard.org # usb start
(Re)start USB…
USB0: ULPI: ulpi_reset: failed writing reset bit
USB EHCI 1.00
scanning bus 0 for devices… 3 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
scanning usb for ethernet devices… Warning: failed to set MAC address
1 Ethernet Device(s) found
OMAP3 beagleboard.org # tftp 0x80000000 uImage
ERROR: Need valid ‘usbnet_devaddr’ to be set
at ether.c:2358/usb_eth_init()
