Hi folks,
Thank you for your valuable suggestions, atlast I was able to debug the application code using eclipse kepler and gdb the target as BBB, but one question I have is that, Will I be able to debug the kernel code in case I implement a method on the kernel space?
Has anyone of tried to build angstrom for BBB using the linaro toolchain instead of the oe setup scripts???
Thanks in advance!!!
Gibson
