On Sun, 2 Sep 2018 00:06:20 +0100, Ichrak Mansour
<ichrakmansour.ing@gmail.com> declaimed the
following:
I'am Sorry ...
Yay! A text cut&paste instead of an image! Thank you.
When I run this command, I get :
root@beaglebone:/home/debian# top -o '%MEM'
Remember -- I said to watch it to see what is using up the memory
(since this command will update periodically)
top - 00:07:42 up 14 min, 1 user, load average: 0.66, 1.51, 1.67
Tasks: 93 total, 1 running, 65 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0.7 us, 1.3 sy, 0.0 ni, 98.0 id, 0.0 wa, 0.0 hi, 0.0 si,
0.0 st
KiB Mem : 494588 total, 24908 free, 409256 used, 60424 buff/cache
KiB Swap: 1048572 total, 956924 free, 91648 used. 71880 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1492 root 20 0 484960 361796 11372 S 0.0 73.2 6:32.76 node
At the moment you did this cut&paste, "node" was sucking up 73% of the
available memory (and practically NO CPU time -- the journal and top are
the CPU users). Unless I misunderstood the documentation for "top", %mem is
based upon the total of RAM and swap. That's nearly 1.2GB right there
(though some is in memory shared with other processes)..
Google on npm, ELIFECYCLE, and react seems to show lots of problems
with it, none with a clear explanation or solution. Some seem to imply a
problem with how packages were installed (mismatches, etc.).
Other than kicking the swap space up to maybe 4GB as a test, I'm now
out of suggestions. I don't do stuff with node.js (I can work with Python
thread, Ada tasking -- but systems based upon asynchronous callbacks just
confuse me, and that is what node.js relies upon; even Python's async
system confuses me). Whatever node is running is sucking up memory, and one
has to be ready to debug node.js source files to make any progress.
