the image for BeagleBoard xfce, 09/02/2023, ver 11.7 is lacking SSH not installed or not enabled
This is the 2nd time that the image got hungup. I was trying to get the IP address, but could not.
Pl mention how to install SSH?
also why the image does not have SSH or enabled?
Now I will be installing the image 3rd time.
This is very discouraging for BBB and waste of time.
Pl help in this respect to move forward smoothly.
ssh debian@192.168.7.2
You can sign in that way where debian is the username while the passcode is temppwd.
Use the IoT image that is on the official list, I know for fact that one is working fine. It only needs gdb and cmake and you are rockin and rolling all night long.
Even the image you are running should be working. How are you connecting it to the network, that is more than likely the problem. Highly doubt its the image.
fred@bbbi4:~$ uname -a
Linux bbbi4 5.10.168-ti-r78 #1bookworm SMP PREEMPT Tue Jul 2 23:29:03 UTC 2024 armv7l GNU/Linux
Thanks Fred, for the response.
I want terminals, IDEs, UI. So I need xfce image.
through USB, which also provides power to the board.
Post the path to the exact image you are trying to use.
Latest Software Images - BeagleBoard
AM335x 11.7 2023-09-02 4GB eMMC Xfce Flasher
Debian image for BeagleBone Black on-board eMMC flash Kernel: 5.10.168-ti-r71 U-Boot: v2022.04 default username:…
](AM335x 11.7 2023-09-02 4GB eMMC Xfce Flasher - BeagleBoard)
Debian image for BeagleBone Black on-board eMMC flash Kernel: 5.10.168-ti-r71 U-Boot: v2022.04 default username:password is [debian:temppwd] For flashing instructions or other images, see Debian 11.x (Bullseye) - Monthly Snapshot - 2023-10-07
The XFCE image for the BBB may be too large for the eMMC.
P.S. I say use the micro SD Card.
the name of the xfce image from the Beagleboard distros that I put on my BBB is:
am335x-eMMC-flasher-debian-11.7-xfce-armhf-2023-09-02-4gb.img
Notes:
This is the only xfce image on distros for BBB.
I don’t see any image on the distros that mentions for micro SD card.
If there is, pl mention its name.
Thanks.
I am disappointed at BBB performance.
It could not be connected to the Internet.
Qt Creator IDE could not be put on it.
Perhaps it has ram disk. What ever programming I do, goes away next time I start BBB.
Any suggestions?
The only image I found on the BB distros for xfce is the one I listed in my previous email.
Just got it running and it is updating from the repository at this moment.
$sudo ifconfig
And lets see what that looks like.
Keep in mind this is a single core board, and a desktop is a heavy load. Did notice it is pretty sluggish getting up and the mouse cursor is on screen for a while then the desktop opens up. Well, it does not have enough room left to upgrade. That means mount your SD card and use fstab to configure it to mount on boot and move some directories over too SD card. You would be better off with a SD card image so you can run desktop directly.
78 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 140 MB of archives.
After this operation, 14.7 MB of additional disk space will be used.
E: You don't have enough free space in /var/cache/apt/archives/.
debian@BeagleBone:~$ df
Filesystem     1K-blocks    Used Available Use% Mounted on
udev              215500       0    215500   0% /dev
tmpfs              49404    1496     47908   4% /run
/dev/mmcblk1p1   3592716 3389760         0 100% /
tmpfs             247004       0    247004   0% /dev/shm
tmpfs               5120       0      5120   0% /run/lock
tmpfs              49400      36     49364   1% /run/user/1000
Run the SD card image for best results, nothing wrong with doing that.
My apologies, but I am giving up on BBB.
I don’t have time to do different experimentations.
Is there a wireless BBB?
| foxsquirrel
August 1 |
babuddin1:
$sudo ifconfig
You would have to move upto a beagley-ai. We don’t use the wireless so that feature has not been tested by us, it is assumed that it works fine and it comes with an antenna.
