From 9045377f255e8a59450a6957e63366b4963281ae Mon Sep 17 00:00:00 2001
Dear Khasim Syed,
I have compiled your patches and they appear to work on a C2 board.
One question/observation:
I can switch by 'i2c dev' to channel #0, #1, and #2. But #3 fails.
AFAIK, there are I2C1 to I2C4 on the OMAP3530. How is the mapping?
Which channel is missing?
And, for channel #0, I can probe addresses 48 to 4B, while channel #1
responds to almost all addresses and channel #2 to none.
Thanks for your good work!
Nikolaus
Dear Khasim Syed,
I have compiled your patches and they appear to work on a C2 board.One question/observation:
I2C4 is for smart reflex to Triton chipset, it is not generic so no
support was added for the same.
Channel 2 will respond when you have DVID monitor connected. Channel 1
has no device connected therefore it shows all sorts of addresses.
Thanks.
Khasim
> Dear Khasim Syed,
> I have compiled your patches and they appear to work on a C2 board.> One question/observation:
> Which channel is missing?I2C4 is for smart reflex to Triton chipset, it is not generic so no
Ah, that is very reasonable...
> responds to almost all addresses and channel #2 to none.Channel 2 will respond when you have DVID monitor connected. Channel 1
So it is (for the records):
channel 0: I2C1 - control bus of TWL4030/TPS65950
channel 1: I2C2 - connected to Expansion Header J3
channel 2: I2C3 - level shifted to DVI connector and directly on video
expansion header J4/J5
n/a: I2C4 - smart reflex
Thanks.
Khasim
Another small observation: when I enter the i2c command without any
parameters, uboot appears to hang with no error message.
