From 9045377f255e8a59450a6957e63366b4963281ae Mon Sep 17 00:00:00 2001
Date: Fri, 8 Jan 2010 20:20:41 +0530
Subject: [PATCH] Enable I2C bus switchingOMAP3 supports Multiple I2C channels, this patch allows
us to use i2c dev <bus no> command to switch between busses.Signed-off-by: Syed Mohammed Khasim <khasim@ti.com>
Acked-by: Heiko Schocher <hs@denx.de>
drivers/i2c/omap24xx_i2c.c | 5 +++++
include/configs/omap3_beagle.h | 4 ++++
2 files changed, 9 insertions(+), 0 deletions(-)
This patch fails to merge because of the recent usb changes in omap.
Please rebase this patchset and resubmit.
diff --git a/drivers/i2c/omap24xx_i2c.c b/drivers/i2c/omap24xx_i2c.c
index ff18991..e8c8184 100644
--- a/drivers/i2c/omap24xx_i2c.c
+++ b/drivers/i2c/omap24xx_i2c.c
@@ -435,3 +435,8 @@ int i2c_set_bus_num(unsigned int bus)return 0;
+int i2c_get_bus_num(void)
+ return (int) current_bus;
diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h
index d1c9cd0..ff6d432 100644
--- a/include/configs/omap3_beagle.h
+++ b/include/configs/omap3_beagle.h
@@ -100,6 +100,10 @@
/* DDR - I use Micron DDR */
#define CONFIG_OMAP3_MICRON_DDR 1+/* Enable Multi Bus support for I2C */
+#define CONFIG_I2C_MULTI_BUS 1
+#define CONFIG_SYS_I2C_NOPROBES {0x0, 0x0}
Most (All ?) of the configs I reviewed set the addr element
to a valid address. I do not believe 0 is a valid address
on omap. If the intent is a double negative
{0, 0} == probe all
then add a comment.
Tom
