From fe824eb530338182503dd75d466374ac2e96c063 Mon Sep 17 00:00:00 2001
Where are these patches being applied to?
Date: Mon, 18 Jan 2010 18:35:40 +0530
Subject: [PATCH] Enable DSS driver for BeagleConfigures DSS to display color bar on Svideo
Configures DSS to display background color on DVIDSigned-off-by: Syed Mohammed Khasim <khasim@ti.com>
board/ti/beagle/beagle.c | 12 ++++++
board/ti/beagle/beagle.h | 75 ++++++++++++++++++++++++++++++++++++++++
include/configs/omap3_beagle.h | 1 +
3 files changed, 88 insertions(+), 0 deletions(-)diff --git a/board/ti/beagle/beagle.c b/board/ti/beagle/beagle.c
index 23985ea..2bf0430 100644
--- a/board/ti/beagle/beagle.c
+++ b/board/ti/beagle/beagle.c
@@ -114,6 +114,16 @@ void beagle_identify(void)
+ * Configure DSS to display background color on DVID
+ * Configure VENC to display color bar on S-Video
+void display_init(void)
This should be static
+ omap3_dss_venc_config(&venc_config_std_tv, VENC_HEIGHT, VENC_WIDTH);
+ omap3_dss_panel_config(&dvid_cfg);
* Routine: misc_init_r
* Description: Configure board specific parts
@@ -124,6 +134,7 @@ int misc_init_r(void)twl4030_power_init();
twl4030_led_init(TWL4030_LED_LEDEN_LEDAON | TWL4030_LED_LEDEN_LEDBON);
+ display_init();
Should be if-defed to CONFIG_VIDEO_OMAP3
/* Configure GPIOs to output */
writel(~(GPIO23 | GPIO10 | GPIO8 | GPIO2 | GPIO1), &gpio6_base->oe);
@@ -139,6 +150,7 @@ int misc_init_r(void)
beagle_identify();dieid_num_r();
+ omap3_dss_enable();
return 0;
diff --git a/board/ti/beagle/beagle.h b/board/ti/beagle/beagle.h
index d1d5d27..3605427 100644
--- a/board/ti/beagle/beagle.h
+++ b/board/ti/beagle/beagle.h
@@ -23,6 +23,8 @@
#ifndef _BEAGLE_H_
#define _BEAGLE_H_+#include <asm/arch/dss.h>
const omap3_sysinfo sysinfo = {
DDR_STACKED,
"OMAP3 Beagle board",
@@ -385,4 +387,77 @@ const omap3_sysinfo sysinfo = {
MUX_VAL(CP(UART2_RTS), (IDIS | PTD | DIS | M0)) /*UART2_RTS*/\
MUX_VAL(CP(UART2_TX), (IDIS | PTD | DIS | M0)) /*UART2_TX*/
This section is dss.
This should move to dss.c or dss.h
+ * Display Configuration
+#define DVI_BEAGLE_ORANGE_COL 0x00FF8000
+#define VENC_HEIGHT 0x00ef
+#define VENC_WIDTH 0x027f
+ * Configure VENC in DSS for Beagle to generate Color Bar
+ * Kindly refer to OMAP TRM for definition of these values.
No good enough.
If you are going to refer people to TRM.
Give them some idea how to find the data.
The name of TRM, the section and maybe quote to help them find
the location..
15.5.8.4 Video Encoder Register Settings
For video encoder programming, see Table 15-67.
This table lists the register values to use in standard
applications. These values are validated programming values only
for the TV display support (NTSC 601 and PAL 601 standards).
Table 15-67. Video Encoder Register Programming Values
Register Name NTSC 601 PAL 601
VENC_F_CONTROL 0x00000000 0x00000000
VENC_VIDOUT_CTRL 0x00000001 0x00000001
VENC_SYNC_CTRL 0x00008040 0x00000040
VENC_LLEN 0x00000359 0x0000035F
VENC_FLENS
You need to qualify std_tv as either ntsc or pal.
Include both setting.
If it is impossible to test PAL, make a note with a big warning
+static const struct venc_regs venc_config_std_tv = {
+ .status = 0x0000001B,
+ .f_control = 0x00000040,
+ .vidout_ctrl = 0x00000000,
?? not 1
+ .sync_ctrl = 0x00008000,
?? not 8040 or 40
+ .llen = 0x00008359,
?? not 359 or 35F
Likely you are using a different TRM than I am.
Please check if there isn't some dependency on dss silicon
revision.
Tom
+void display_init(void)This should be static
ok
VENC_WIDTH);
@@ -124,6 +134,7 @@ int misc_init_r(void)twl4030\_power\_init\(\); twl4030\_led\_init\(TWL4030\_LED\_LEDEN\_LEDAON |TWL4030_LED_LEDEN_LEDBON);
+ display_init();Should be if-defed to CONFIG_VIDEO_OMAP3
ok
/\* Configure GPIOs to output \*/ writel\(\~\(GPIO23 | GPIO10 | GPIO8 | GPIO2 | GPIO1\),&gpio6_base->oe);
beagle_identify();dieid\_num\_r\(\);+ omap3_dss_enable();
ok
return 0;}
@@ -23,6 +23,8 @@
#ifndef _BEAGLE_H_
DDR_STACKED,
/*UART2_RTS*/\
/*UART2_TX*/This section is dss.
This should move to dss.c or dss.h+/*
No, they are board specific, so should be in board file. They don't
belong to DSS.
+ */No good enough.
the location..
Sure.
VENC_FLENS
HUH ....
I was under an impression that people who really code, read TRM and
they don't need this level of details. I will give the section details
for sure.
But I feel you are asking some thing un necessarily more.... There
are tons of programming, if every one does this then u-boot code will
become a document portal. ![]()
I was not interested in confusing others on the ntsc or pal. But any
way I test NTSC, I can change the name accordingly. I will not add the
structure for PAL, will wait for some one to send out patch for PAL if
interested.
Why warning when I am saying that it is NTSC, can we not understand
that NTSC is not PAL ![]()
+ .vidout_ctrl = 0x00000000,?? not 1
?? not 8040 or 40
?? not 359 or 35F
revision.
There might be some differences, I am taking values that were working
before for me from the kernel. If some one needs they can do the TRM
comparison, PLEASE UNDERSTAND this is not for building your PRODUCT
around this, it is for TESTING THE BOARD FOR TV OUT And nothing BEYOND
THIS. Hope you understand the need for this driver in u-boot.
You always have access to TRM and register definition, they can see
what is getting changed and why.
Khasim
<snip>
/*UART2_TX*/
+#define VENC_WIDTH 0x027fNo, they are board specific, so should be in board file. They don't
belong to DSS.
Ok
+ */No good enough.
the location..Sure.
VENC_FLENSHUH ....
for sure.
I don't mean for you to quote large sections of TRM like this
just provide enough information, title, version of doc, section
that will help the next person find where these values came from
become a document portal.You need to qualify std_tv as either ntsc or pal.
interested.
Ok just ntsc
There should at least be a comment somewhere that this is ntsc.
I realize PAL is hard to test without a monitor.
If it is impossible to test PAL, make a note with a big warningWhy warning when I am saying that it is NTSC, can we not understand
that NTSC is not PAL+static const struct venc_regs venc_config_std_tv = {
?? not 8040 or 40
?? not 359 or 35F
revision.There might be some differences, I am taking values that were working
THIS. Hope you understand the need for this driver in u-boot.You always have access to TRM and register definition, they can see
I was pointing out that without a version number of the TRM or a kernel
commit id, it is difficult to verify or change the values given.
All this needs is better comment on where the values came from.
Tom
