Hi *,
when writing the image file to the SD card, is it normal that it takes around 30 minutes?
I use sudo xz -kdcv Angstrom-image…xz > /dev/disk1
and I can observe the the xz process consumes almost no CPU or Memory (on Mac OS X 10.7). Is there a way to speed things up? I could not find the sdcard device as outlined in the how tos, at least after I unmounted /dev/disk1 it works, but it is normal to be that slow?
Markus
Hi *,
45 minutes on my macs, there's something wonky with the SD drivers in OSX
I use sudo xz -kdcv Angstrom-image...xz > /dev/disk1
It's indeed really slow.
regards,
Koen
It also depends on the SD card speed, there is a great difference between a class 10 and a class 2.
Class 10 is really fast.
Daniel
I just discovered that using an USB card reader instead of the SD card slot on Mac OS X brings down the time to 12 minutes. I can live with that.
Markus
2012/3/2 Robert Nelson <robertcnelson@gmail.com>
