If your only getting "CCC" thru the serial terminal, then the
rom-based bootloader failed to find the MLO in your boot partition...
Re-Format the boot partition and reset the bootflag before coping the
MLO file before anything else to it..
When I try to boot, I only get “CCCCC” through the console. Can anyone see
what I’m doing wrong?
If your only getting “CCC” thru the serial terminal, then the
rom-based bootloader failed to find the MLO in your boot partition…
Thanks Robert, I did that and the kernel loads fine but init fails:
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
devtmpfs: error mounting -2
Freeing init memory: 144K
Failed to execute /init. Attempting defaults…
Kernel panic - not syncing: No init found. Try passing init= option to kernel.
