I downloaded the Android build from
http://labs.embinux.org/index.php/Android_For_OMAP3_with_Gstreamer_Integration.
My Question is -
1.Do I need to build it as it is or Do I need to modify the build as
per the instructions given in http://labs.embinux.org/index.php/Toolchain_For_Android?
2.After download when I gave the make, I got some compilation errors,
but if I do make clean and then make, it seems to continue the build.
Does the android build gets compiled as is(without any toolchain
modifications).
I am not keen on any particular toochain as long as the setup works
fine for me on beagle board. My objective is to run the Android demo
as is first and later drop my H.264 component and than run it.
Sanjeev Kumar Verma
Sanjeev,
Android build that you have downloaded already contains integrated
Embinux toolchain, and you do not modify anything for toolchain. Android
build should compile without any errors.
If you face any errors let me know.
Regards
ACtually build is failing if I compile it as it is with following
error. Plz let me know what to do to resolve it.
/home/ittiam/hdd/omap3droid/prebuilt/linux-x86/toolchain/arm-
eabi-4.4.0/bin/../libexec/gcc/arm-eabi/4.4.0/cc1: error while loading
shared libraries: libmpfr.so.1: cannot open shared object file: No
such file or directory
make[3]: *** [kernel/bounds.s] Error 1
make[2]: *** [prepare0] Error 2
make[1]: *** [sub-make] Error 2
make[1]: Leaving directory `/home/ittiam/hdd/omap3droid/kernel'
make: *** [out/target/product/beagle/obj/KERNEL_OBJ/arch/arm/boot/
uImage] Error 2
well then install libmpfr....
I just did locate libmpfr
I could see the following results -
/OE/angstrom-dev/staging/i686-linux/usr/lib/libmpfr.a
/OE/angstrom-dev/staging/i686-linux/usr/lib/libmpfr.la
/OE/angstrom-dev/staging/i686-linux/usr/lib/libmpfr.so
/OE/angstrom-dev/staging/i686-linux/usr/lib/libmpfr.so.1
/OE/angstrom-dev/staging/i686-linux/usr/lib/libmpfr.so.1.1.1
Can you please tell me how to include this path in android build. I
did export PATH=/OE/angstrom-dev/staging/i686-linux/usr/lib:$PATH but
this does not help
Sanjeev
On ubuntu you can do,
$ sudo apt-get install libmpfr1ldbl
Is there any way to find out that the my downloaded stuff (omap3droid)
is complete in itself. I want to verify that it is not partial due to
any kind or constraint like low disk space or network fluctuation etc.
Sanjeev Kumar Verma
this does not help
no, your host system needs libmpfr
Rupesh,
My Build is failing again with the following Error:-
'%d' expects type 'int', but argument 5 has type 'ssize_t'
target thumb C++: libaudiointerface <= frameworks/base/libs/
audioflinger/AudioHardwareStub.cpp
audioflinger/AudioDumpInterface.cpp
audioflinger/AudioHardwareInterface.cpp
target StaticLib: libaudiointerface (out/target/product/beagle/obj/
STATIC_LIBRARIES/libaudiointerface_intermediates/libaudiointerface.a)
target arm C: libasound <= external/alsa-lib/src/alisp/alisp.c
external/alsa-lib/src/alisp/alisp.c: In function 'obj_type_str':
external/alsa-lib/src/alisp/alisp.c:1024: error: control reaches end
of non-void function
make: *** [out/target/product/beagle/obj/STATIC_LIBRARIES/
libasound_intermediates/src/alisp/alisp.o] Error 1
root@ittiam-desktop:/home/ittiam/hdd/omap3droid#
anybody's help would be highly appreciated!
Sanjeev Kumar Verma
Are syntax Errors expected in the build?
Sanjeev Kumar Verma
Sanjeev,
Can you add statement “return 0;” at the end of “obj_type_str()” function in file
“external/alsa-lib/src/alisp/alisp.c:1024”
I think this patch is missing from our repositories.
Thanks all,
My build is successfull. Got the file system but where is uImage? I
could not find it.
I know that u-bbot.bin and MLO will not be generated.
Sanjeev Kumar Verma
Do I need to rename kernel in out/target/product/beagle/ as uImage?
Regards, Sanjeev Kumar Verma wrote:
Rupesh Gujare wrote:
Sanjeev,
could you also make available the configure commands to rebuild your toolchains and binutils?
Vladimir
