Trouble Booting via initramfs - Free Electrons
I've been working my way through the Free Electrons Beagle Labs [1].
They are a good way to learn all that goes on when booting up and
running a BeagleBoard. However I've hit a snag.
Instructions are given for building a kernel that boots via
initramfs. When the OE kernel boots it uses a separate partition on
the SD card for the root file system. When you use initramfs the
separate partition isn't needed. Rather the whole root file system is
contained in a cpio file that is compiled in the kernel.
Unfortunately I haven't been able to get it to work. [2] shows the
output of the boot sequence.
I have two questions.
1. Why isn't it working.
2. What process should I follow to solve the problem?
Question 2 is the more important one. I want to teach my students a
process they can follow that help them solve the common (and not so
common) problems. However I don't know enough of the process to help
myself.
Thanks for your help...
--Mark
[1] http://free-electrons.com/blog/beagle-labs/
[2]
Texas Instruments X-Loader 1.4.2 (Dec 18 2009 - 21:57:52)
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2009.11-00134-g87d93a1-dirty (Dec 18 2009 - 22:17:30)
OMAP3530-GP ES3.0, CPU-OPP2 L3-165MHz
I2C: ready
DRAM: 128 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Board revision Ax/Bx
Die ID #5ac400030000000004013f8901001001
OMAP3 beagleboard.org # mmc init
mmc1 is available
OMAP3 beagleboard.org # fatload mmc 0 80000000 uImage
reading uImage
2437136 bytes read
OMAP3 beagleboard.org # bootm 80000000
## Booting kernel from Legacy Image at 80000000 ...
   Image Name: Linux-2.6.33-rc1-06876-ga468c91-
   Data Size: 2437072 Bytes = 2.3 MB
   Load Address: 80008000
   Entry Point: 80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing
Linux.............................................................
............. done, booting the kernel.
Linux version 2.6.33-rc1-06876-ga468c91-dirty (yoder@vmware-ubuntu)
(gcc version
4.3.2 (crosstool-NG-1.4.2) ) #6 Thu Dec 24 03:36:17 EST 2009
CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: OMAP3 Beagle Board
Memory policy: ECC disabled, Data cache writeback
OMAP3430/3530 ES3.0 (l2cache iva sgx neon isp )
SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x100000
Built 1 zonelists in Zone order, mobility grouping on. Total pages:
32512
Kernel command line: console=ttyS2,115200n8 console=tty0 root=/dev/
mmcblk0p2 rw
rootfstype=ext3 rootwait omapfb.mode=dvi:1024x768MR-16@60
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 124856KB available (3368K code, 293K data, 1136K init, 0K
highmem)
Hierarchical RCU implementation.
RCU-based detection of stalled CPUs is enabled.
NR_IRQS:402
Clocking rate (Crystal/Core/MPU): 26.0/332/500 MHz
Reprogramming SDRC clock to 332000000 Hz
GPMC revision 5.0
IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
Total of 96 interrupts on 1 active controller
OMAP GPIO hardware version 2.5
OMAP clockevent source: GPTIMER12 at 32768 Hz
Console: colour dummy device 80x30
console [tty0] enabled
Calibrating delay loop... 478.91 BogoMIPS (lpj=1867776)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
regulator: core version 0.5
NET: Registered protocol family 16
Found NAND on CS0
Registering NAND on CS0
OMAP DMA hardware revision 4.0
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
twl4030: PIH (irq 7) chaining IRQs 368..375
twl4030: power (irq 373) chaining IRQs 376..383
twl4030: gpio (irq 368) chaining IRQs 384..401
regulator: VUSB1V5: 1500 mV normal standby
regulator: VUSB1V8: 1800 mV normal standby
regulator: VUSB3V1: 3100 mV normal standby
twl4030_usb twl4030_usb: Initialized TWL4030 USB module
regulator: VMMC1: 1850 <--> 3150 mV at 3000 mV normal standby
regulator: VDAC: 1800 mV normal standby
regulator: VDVI: 1800 mV normal standby
regulator: VSIM: 1800 <--> 3000 mV at 1800 mV normal standby
i2c_omap i2c_omap.3: bus 3 rev3.12 at 100 kHz
Switching to clocksource 32k_counter
musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
musb_hdrc: USB OTG mode controller at fa0ab000 using DMA, IRQ 92
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
JFFS2 version 2.2. (NAND) B) 2001-2006 Red Hat, Inc.
msgmni has been set to 244
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
omapfb: configured for panel omap3beagle
omapfb: DISPC version 3.0 initialized
Console: switching to colour frame buffer device 128x48
omapfb: Framebuffer initialized. Total vram 1572864 planes 1
omapfb: Pixclock 61714 kHz hfreq 57.5 kHz vfreq 74.2 Hz
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
console [ttyS2] enabled
brd: module loaded
loop: module loaded
usbmon: debugfs is not available
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 3 ports detected
i2c /dev entries driver
TCP cubic registered
NET: Registered protocol family 17
NET: Registered protocol family 15
Power Management for TI OMAP3.
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev
1
regulator_init_complete: incomplete constraints, leaving VDVI on
regulator_init_complete: incomplete constraints, leaving VDAC on
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
Freeing init memory: 1136K
mmc0: new high speed SD card at address 1145
mmcblk0: mmc0:1145 SD02G 1.83 GiB
mmcblk0: p1
I've only glimpsed over the tut, but I think your boot args are not right.
See below
myself.
--Mark
[1] Embedded Linux practical labs with the Beagle Board - Bootlin's blog
[2]
Reading boot sector
I2C: ready
DRAM: 128 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
mmc1 is available
reading uImage
2437136 bytes read
OK
Starting kernel ...
Uncompressing
(gcc version
32512
mmcblk0p2 rw
This says your rfs is on partition2 and is an ext3 rfs. That does not
sound good for initramfs.
It's been a while since I did an initramfs, but I recall that the
documentation in the kernel tree explains things (and otherwise
definitely google can help you out)
FM
I've poked around Document/filesystems/ramfs-rootfs-initramfs.txt and
don't find anything about kernel parameters. The ones you saw are the
defaults from U-boot. The tutorial didn't say any other parameters
needed to be used.
Is there a way to have the kernel tell me more about why it stopped?
--Mark
mmcblk0: p1
It looks like it might have mounted your root filesystem, and if so that
means it isn't a kernel problem per se--- the problem is either purely
user-side, or in a user-kernel interaction. It could be that your
kernel is configured for EABI, but your userspace is built as OABI. Or
vise-versa. Make sure your kernel is configured to support both.
b.g.
