Trouble Booting with Latest Image
I have two beagle bone boards, which I have erased the eMMC flash on both to ensure it is booting off of the SD card when installed (CCC on terminal to verify erased)
One beagle bone will install just fine and the other won’t.
I’m using the following image
am335x-eMMC-flasher-debian-11.7-iot-armhf-2023-09-02-4gb
The serial output from the one that won’t install is below
[02]CCCCCCCCCCCCCCCC
U-Boot SPL 2022.04-ge0d31da5 (Aug 04 2023 - 18:48:26 +0000)
Trying to boot from MMC1
U-Boot 2022.04-ge0d31da5 (Aug 04 2023 - 18:48:26 +0000)
CPU  : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM:  512 MiB
RTC 32KCLK Source: External.
Core:  150 devices, 14 uclasses, devicetree: separate
WDT:   Started wdt@44e35000 with servicing (60s timeout)
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Loading Environment from EXT4... Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
Model: BeagleBone Black Industrial:
BeagleBone Cape EEPROM: no EEPROM at address: 0x54
BeagleBone Cape EEPROM: no EEPROM at address: 0x55
BeagleBone Cape EEPROM: no EEPROM at address: 0x56
BeagleBone Cape EEPROM: no EEPROM at address: 0x57
Net:   eth2: ethernet@4a100000, eth3: usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[A335BNLT] ...
board_rev=[EIA0] ...
switch to partitions #0, OK
** No partition table - mmc 1 **
Couldn't find partition mmc 1:1
Checking for: /uEnv.txt ...
Checking for: /boot/uEnv.txt ...
Couldn't find partition mmc 1:2
Couldn't find partition mmc 1:3
Couldn't find partition mmc 1:4
Couldn't find partition mmc 1:5
Couldn't find partition mmc 1:6
Couldn't find partition mmc 1:7
starting USB...
Bus usb@47401800: Port not available.
USB is stopped. Please issue 'usb start' first.
starting USB...
ethernet@4a100000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in
MAC de:ad:be:ef:00:01
HOST MAC de:ad:be:ef:00:00
RNDIS ready
missing environment variable: pxeuuid
Retrieving file: pxelinux.cfg/01-6c-30-2a-eb-a9-09
RNDIS ready
Retrieving file: pxelinux.cfg/00000000
RNDIS ready
[00][00][00]
On the board that is not working, in u-boot I try to see the contents of the SD card
DRAM:  512 MiB
BeagleBone Black:
=> mmc list
OMAP SD/MMC: 0
OMAP SD/MMC: 1
=> ls mmc 0:1
Couldn't find partition mmc 0:1
=> ls mmc 1:1
On the board that does work properly
[00]CCCCCCCCCCCCCCCC
DRAM:  512 MiB
Loading Environment from EXT4... ** File not found /boot/uboot.env **
** Unable to read "/boot/uboot.env" from mmc0:1 **
BeagleBone Black:
mmc0 is current device
SD/MMC found on device 0
Couldn't find partition 0:2 0x82000000
Can't set block device
Scanning mmc 0:1...
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
[1B]7[1B][r[1B][999;999H[1B][6n[1B]8Scanning disk mmc@48060000.blk...
Scanning disk mmc@481d8000.blk...
Found 3 disks
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
1712 bytes read in 3 ms (556.6 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-5.10.168-ti-r71 ...
11342336 bytes read in 716 ms (15.1 MiB/s)
debug: [enable_uboot_overlays=1] ...
debug: [enable_uboot_cape_universal=1] ...
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot-univ.dtb ...
loading /boot/dtbs/5.10.168-ti-r71/am335x-boneblack-uboot-univ.dtb ...
210757 bytes read in 19 ms (10.6 MiB/s)
Found 0 extension board(s).
uboot_overlays: [fdt_buffer=0x60000] ...
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r71/overlays/BB-ADC-00A0.dtbo ...
645 bytes read in 5 ms (126 KiB/s)
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r71/overlays/BB-BONE-eMMC1-01-00A0.dtbo ...
1605 bytes read in 5 ms (313.5 KiB/s)
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r71/overlays/BB-HDMI-TDA998x-00A0.dtbo ...
5321 bytes read in 5 ms (1 MiB/s)
loading /boot/initrd.img-5.10.168-ti-r71 ...
7719588 bytes read in 493 ms (14.9 MiB/s)
debug: [console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait init=/usr/sbin/init-beagle-flasher] ...
debug: [bootz 0x82000000 0x88080000:75caa4 88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0xad1200 ]
## Flattened Device Tree blob at 88000000
   Loading Ramdisk to 8f8a3000, end 8ffffaa4 ... OK
   Loading Device Tree to 8f80b000, end 8f8a2fff ... OK
Starting kernel ...
On the board that is working, in u-boot I try to see the contents of the SD card
CCCCCCCCCCCCC
DRAM:  512 MiB
Reset Source: Global warm SW reset has occurred.
BeagleBone Black:
=> mmc list
OMAP SD/MMC: 0 (SD)
OMAP SD/MMC: 1
=> ls mmc 0:1
<DIR>       4096 .
<DIR>       4096 ..
<DIR>      16384 lost+found
              53 ID.txt
<DIR>       4096 sys
<DIR>       4096 lib
<DIR>       4096 tmp
<DIR>       4096 dev
<DIR>       4096 usr
<DIR>       4096 srv
<DIR>       4096 boot
<DIR>       4096 mnt
<DIR>       4096 bin
<DIR>       4096 run
<DIR>       4096 root
<DIR>       4096 media
<DIR>       4096 opt
<DIR>       4096 proc
<DIR>       4096 sbin
<DIR>       4096 home
<DIR>       4096 etc
<DIR>       4096 var
=> ls mmc 1:1
However if I grab an older version of the beagle bone image
bone-eMMC-flasher-debian-10.3-iot-armhf-2020-04-06-4gb.img
On the board that did not work with the newer image here is the serial output
U-Boot SPL 2019.04-00003-g2bf638a03e (Mar 06 2020 - 11:25:08 -0600)
U-Boot 2019.04-00003-g2bf638a03e (Mar 06 2020 - 11:25:08 -0600), Build: jenkins-github_Bootloader-Builder-137
I2C:   ready
DRAM:  512 MiB
No match for driver 'omap_hsmmc'
Some drivers were not found
BeagleBone Black:
Model: Element14 BeagleBone Black Industrial:
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net:   eth0: MII MODE
cpsw, usb_ether
Press SPACE to abort autoboot in 2 seconds
Scanning mmc 0:1...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
2004 bytes read in 87 ms (22.5 KiB/s)
loading /boot/vmlinuz-4.19.94-ti-r42 ...
10095592 bytes read in 710 ms (13.6 MiB/s)
loading /boot/dtbs/4.19.94-ti-r42/am335x-boneblack-uboot-univ.dtb ...
162266 bytes read in 126 ms (1.2 MiB/s)
uboot_overlays: loading /lib/firmware/BB-ADC-00A0.dtbo ...
867 bytes read in 1019 ms (0 Bytes/s)
uboot_overlays: loading /lib/firmware/BB-BONE-eMMC1-01-00A0.dtbo ...
1584 bytes read in 1348 ms (1000 Bytes/s)
uboot_overlays: loading /lib/firmware/BB-HDMI-TDA998x-00A0.dtbo ...
4915 bytes read in 545 ms (8.8 KiB/s)
uboot_overlays: loading /lib/firmware/AM335X-PRU-RPROC-4-19-TI-00A0.dtbo ...
3801 bytes read in 254 ms (13.7 KiB/s)
loading /boot/initrd.img-4.19.94-ti-r42 ...
6589689 bytes read in 494 ms (12.7 MiB/s)
debug: [console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh] ...
debug: [bootz 0x82000000 0x88080000:648cf9 88000000] ...
   Loading Ramdisk to 8f9b7000, end 8ffffcf9 ... OK
   Loading Device Tree to 8f92b000, end 8f9b6fff ... OK
Starting kernel ...
On the board that worked with the newer image here is the serial output
CCCCCCCCCCCCCCCCC
I2C:   ready
DRAM:  512 MiB
BeagleBone Black:
Net:   eth0: MII MODE
cpsw, usb_ether
Scanning mmc 0:1...
2004 bytes read in 107 ms (17.6 KiB/s)
10095592 bytes read in 718 ms (13.4 MiB/s)
162266 bytes read in 158 ms (1002.9 KiB/s)
867 bytes read in 1505 ms (0 Bytes/s)
1584 bytes read in 2010 ms (0 Bytes/s)
4915 bytes read in 776 ms (5.9 KiB/s)
3801 bytes read in 343 ms (10.7 KiB/s)
6589689 bytes read in 505 ms (12.4 MiB/s)
Starting kernel ...
Does anyone have any idea what might cause this?
before i download and test, do you have a good power source ??
Yes using a 5v 2A wall wart
am335x-eMMC-flasher-debian-11.7-iot-armhf-2023-09-02-4gb.img.xz
burned to cheap sd card with balenaEtcher-1.5.70-x64
booted fine, auto wrote image to emmc which also booted fine.
my BBB is from 2017 time frame, JFYI
does your BBB have the Kingston emmc that goes bad. there are other recent post on this site, maybe look at some of those.
There is some difference between the two boards I have and between the images.
The one board is from 2020 and will boot with what ever I throw at it
The other board is from 2023 and it will not boot from the latest image but will boot from and install from the following image
When I say it won’t boot, I mean it won’t install the image to the eMMC.
For whatever reason on the latest image the board from 2023 will not recognize the SD card beyond loading u-boot. But with the older image it is recognized fine and loads
your 2023 might be the Kingston emmc issue.
not sure what @RobertCNelson uses to see emmc info. he posted the model number or something one day. this is the link to the discussion.
MK2704 Kingston 4gb eMMC
I assume so, but need to ask, is this the same physical microSD for both boards? If so, normally a failure to read, could be a bent pin in the microSD.
Booting with U-Boot 2022.04 and not reading the partition table is weird, as then placing U-Boot 2019.04 it works…
IDK, very odd.
Might be worth it to try:
Debian 11 IOT: https://rcn-ee.net/rootfs/debian-armhf-11-bullseye-iot-v5.10-ti/2024-07-17/am335x-debian-11.10-iot-armhf-2024-07-17-4gb.img.xz
Debian 12 IOT: https://rcn-ee.net/rootfs/debian-armhf-12-bookworm-iot-v5.10-ti/2024-07-17/am335x-debian-12.6-iot-armhf-2024-07-17-4gb.img.xz
To see if it’s something else…
From the board that is having issues:
BBB   hostname   beaglebone
BBB   version    EIA0
BBB   serial     2425SBI00745
eMMC  name       W62704
eMMC  date       05/2023
eMMC  rev        0x8
eMMC  hwrev      0x0
eMMC  fwrev      0x0200000000000000
eMMC  oemid      0x0100
eMMC  manfid     0x000070
eMMC  life_time  0x01                0x01
eMMC  serial     0x16288c01
From the board that does not have issues
BBB   version    EIA0
BBB   serial     2103SBI18304
eMMC  name       W62704
eMMC  date       11/2020
eMMC  rev        0x8
eMMC  hwrev      0x0
eMMC  oemid      0x0100
eMMC  serial     0x3a83a3ab
It is the same SD card for every test. I don’t think it could be a bent pin as the older image works, also I have a few boards like this where the latest image won’t install but the older one does
I will try those images and report.
Tried both of those images and same result, worked on the 2020 board and did not work on the 2023 board
Serial Console of 2023 Board
U-Boot SPL 2022.04-gbaca7b46 (Jan 15 2024 - 19:59:28 +0000)
U-Boot 2022.04-gbaca7b46 (Jan 15 2024 - 19:59:28 +0000)
DRAM:  512 MiB
BeagleBone Black:
starting USB...
starting USB...
RNDIS ready
I’m not sure but I think something in the newer versions of u-boot are not allowing it to see MMC0
any other suggestions?
