I am totally a nenwbie to BBB - I am having trouble connecting it to my pc through ethernet. I am using Angstrom. I’ve tried following the instructions here: http://derekmolloy.ie/set-ip-address-to-be-static-on-the-beaglebone-black/ but then I run into lots of errors:
login as: root
root@beaglebone.local’s password:
root@beaglebone:~# ls -al
total 64
drwxr-xr-x 10 root root 4096 Jan 1 00:00 .
drwxr-sr-x 4 root root 4096 Mar 18 2013 …
-rw------- 1 root root 1320 Jan 1 00:00 .ICEauthority
-rw------- 1 root root 190 Jan 1 2000 .bash_history
drwxr-xr-x 4 root root 4096 Jan 1 00:01 .config
-rw-r–r-- 1 root root 31 Jan 1 00:00 .dmrc
drwx------ 4 root root 4096 Jan 1 00:00 .gconf
drwx------ 5 root root 4096 Jan 1 00:01 .gnome2
dr-x------ 2 root root 0 Jan 1 00:00 .gvfs
drwxr-xr-x 3 root root 4096 Jan 1 00:00 .local
drwxr-xr-x 2 root root 4096 Jan 1 00:01 .nautilus
drwx------ 2 root root 4096 Jan 1 00:00 .pulse
-rw------- 1 root root 256 Jan 1 00:00 .pulse-cookie
-rw------- 1 root root 7 Jan 1 00:16 .python-history
-rw------- 1 root root 1501 Jan 1 00:00 .xsession-errors
-rw------- 1 root root 1501 Jan 1 00:00 .xsession-errors.old
drwxr-xr-x 2 root root 4096 Jan 1 00:01 Desktop
root@beaglebone:~# route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.7.0 0.0.0.0 255.255.255.252 U 0 0 0 usb0
root@beaglebone:~# cat /etc/network/interfaces
cat: /etc/network/interfaces: No such file or directory
root@beaglebone:~# iface eth0 inet dhcp
-sh: iface: command not found
root@beaglebone:~# /etc/network/interfaces
-sh: /etc/network/interfaces: No such file or directory
root@beaglebone:~#
I cannot find the ethernet_c8a030ab323a_cable# Derek speaks about, I cannot fint the /etc/network/interfaces to try to edit the file indicated by Derek.
Any idea why I am getting those errors? You help will be greatly appreciated.
Thanks in advance!
Lidia
