So I’ve been having issues loading a custom DTO on my Beaglebone Black (well, green, really…). Anyway…
I’ve been following the book Exploring Beaglebone because there’s a lot of good information here. I’ve made a custom .dtbo with pin settings that I’m interested in using because I want to interface with the PRU. I try to run the command
So then I figured maybe I could just go into slots and edit the file to include the name (I’m thinking that the part number is the correct thing to add to this?) manually. When I try to edit /sys/…/slots and save it using nano, I get an error that the file doesn’t exist.
Anyone else have any trouble loading a DTO? Am I missing something?
So I've been having issues loading a custom DTO on my Beaglebone Black
(well, green, really..). Anyway..
I've been following the book Exploring Beaglebone because there's a lot of
good information here. I've made a custom .dtbo with pin settings that I'm
the command
include the name (I'm thinking that the part number is the correct thing to
add to this?) manually. When I try to edit /sys/.../slots and save it using
nano, I get an error that the file doesn't exist.
This isn’t true, I can definitely cd into that directory and it does exist. I have also given 777 permisions to that entire directory in case there was some weird permission thing going on…
Wanted to bump this in case anyone has seen anything like it. Instead of making my own DTO, I tried to load the DTO from the libpruio repo. I don’t get any error when I try to echo the cape to the cape manager slots path… Here are the artifacts from my latest session…
root@beaglebone:/home/libpruio/libpruio-0.2# sudo sh -c “echo libpruio >> /sys/devices/bone_capemgr.9/slots”
Looking at dmesg for startup of the board it turns out that it does matter what you set the compatability field to in the DTO. I got it to apply… Feels good!
