trouble running opkg update - problem with name resolution.
when I run:
opkg update
on my beaglebone it fails with the following errors:
Downloading http://feeds.angstrom-distribution.org/feeds/v2012.12/ipk/eglibc/armv7a-vfp-neon/base/Packages.gz.
wget: bad address ‘feeds.angstrom-distribution.org’
Downloading http://feeds.angstrom-distribution.org/feeds/v2012.12/ipk/eglibc/armv7a-vfp-neon/machine/beaglebone/Packages.gz.
Downloading http://feeds.angstrom-distribution.org/feeds/v2012.12/ipk/eglibc/armv7a-vfp-neon/debug/Packages.gz.
Downloading http://feeds.angstrom-distribution.org/feeds/v2012.12/ipk/eglibc/armv7a-vfp-neon/gstreamer/Packages.gz.
Downloading http://feeds.angstrom-distribution.org/feeds/v2012.12/ipk/eglibc/all/Packages.gz.
Downloading http://feeds.angstrom-distribution.org/feeds/v2012.12/ipk/eglibc/armv7a-vfp-neon/perl/Packages.gz.
Downloading http://feeds.angstrom-distribution.org/feeds/v2012.12/ipk/eglibc/armv7a-vfp-neon/python/Packages.gz.
Collected errors:
opkg install
fails with similar errors, i.e. it seems wget has a problem with the hostname or name resolution. any idea why?
The bone can get out to the internet just fine (though I wish traceroute were installed) as I can ping external hosts such as 4.2.2.4. trying to ping by hostname such as
ping google.com
yields
ping: unknown host google.com
route looks proper as it outputs:
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default 192.168.1.1 0.0.0.0 UG 0 0 0 eth0
192.168.1.0 * 255.255.255.0 U 0 0 0 eth0
192.168.1.1 * 255.255.255.255 UH 0 0 0 eth0
192.168.7.0 * 255.255.255.252 U 0 0 0 usb0
/etc/resolv.conf looks a bit suspect though as it’s contents are below:
Generated by Connection Manager
nameserver 127.0.0.1
when the bone booted it got it’s address from the network dhcp server. should it have not set up it’s default nameservers as well?
note adding a valid nameserver line to /etc.resolv.conf instantly fixed the problem. Now how can this be set to do so automatically when dhcp dynamically configures the angstrom host?
Eric
Sometimes updating the kernel causes the dns server to fail locally. Add an extra nameserver to /etc/resolv.conf.
I do this via a sh script:
I am having the exact same problem. Please can you help me out with steps to avoid this.
