I am using BBB with Robert Nelsons Ubuntu 13.04 (Sept release I think). Everything has worked perfectly up till now. I am trying to add the UARTS based on the Adafruit python library package. It looks like the dts files are not getting compiled and place in the /lib/firmware directory. So I did a compile test with a sample dts file and it gives me the -@ compiler flag error. research directed me to Robert Nelsons patch dtc.sh at https://raw.github.com/RobertCNelson/tools/master/pkgs/dtc.sh . However when I run this script it ends with the error "Failed to fetch http://ftp.linux-foundation.org/pub/lsb/repositories/debian/dists/lsb-4.0/main/binary-armhf/Packages 404 Not found. I went to that site and there are no binary-armhf directories at all. I am stuck. What should i do next? Thanks
Thanks for the response and the great tools you supply but I guess due to my “newbie-ness” I don’t understand your reply. Why is the DTC not working and/or thepatch not working on my BBB with Ubuntu so I can compile dts files? Is it just something messed up on my system?
YOU ARE DA MAN! I have no idea how that reference to lsb-4.0 got in the sources.list file but once i removed it your script ran perfectly. All is well again! Thanks so much.
